Old 12-22-2008, 06:11 PM   #15
tinsltootsie's Avatar
Thanks for all the ideas. My trailer is an overlander 1974 with "skylight" kind of windows. Those do leak, and I'm working on them. Right now, it's winter, and there is very little running water. The leak usually appears in storage, when sitting. I'll keep checking and use many ideas once it thaws and we're getting ready to use it.
It's the rivets!!!!!
tinsltootsie is offline   Reply With Quote
Old 12-22-2008, 07:14 PM   #16
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
I had a '76 Overlander that had missing rivets behind the beltline & rubrail stripes. It took me forever to find those (sealed all windows, vents, etc first). I had a wet floor after rain, but nothing coming from above it. After I discovered the missing rivets & repaired those, I went all the way around & sealed every rivet under both the beltline & rubrail stripes. No more leaks after that. Good luck!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 12-29-2008, 07:42 AM   #17
beltline info
Thanks, Becky, I will definitely check that come spring.
Classic FB Limited (Front Bed vs Front Couch) Sky 2006 - 2010 Classic (all lengths) 38 08-07-2011 07:42 PM
front window leak cadmando Lights - Interior & Exterior 3 10-01-2007 05:44 PM
Leak Alaska1966 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 09-11-2007 12:07 PM
Front Holding Tank Leak Deejay Fresh Water Systems 0 07-08-2003 07:29 AM
possible plumbing leak or water leak jamesl Repairing/Replacing Floor &/or Frame 1 04-06-2003 10:52 AM
