Old 03-10-2015, 05:57 PM   #1
ewbradshaw's Avatar
2008 27' International FB
Sioux Falls , South Dakota
Fresh Water Inlet
Having replaced the fresh water inlet device, what is the best sealant for this against the outside skin?
Also, when reselling roof stuff, does one scrape off the old and reapply?
Thanks for your help!
ewbradshaw is offline   Reply With Quote
Old 03-11-2015, 02:20 PM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
I used the Trempro "vulkem" product often recommended here when I did mine.
Parbond would also work in most cases, as long as you aren't filling a thick gap.
Old 03-11-2015, 07:18 PM   #3
dznf0g's Avatar
Oswego , Illinois
I used Parbond for the fill door. I always remove as much old sealer as possible before laying the new.
-Rich-
Fresh Water Inlet Replacement rayandre 1970 Overlander 0 04-22-2013 06:38 PM
Fresh Water Tank Inlet Recommendations mello mike Fresh Water Systems 18 10-08-2010 01:08 PM
Fresh Water fill from City Inlet question Distantdrummer Fresh Water Systems 7 07-15-2010 05:38 PM
Fresh water inlet location Apache_Camp Plumbing - Systems & Fixtures 0 08-04-2009 08:26 AM
Fresh water inlet William Ales Fresh Water Systems 0 10-11-2006 08:32 PM
