Old 10-29-2015, 11:19 AM   #1
1993 25' Excella
CLeveland , Ohio
Foam or Rubber?
Please take a look at the pictures. Should the doors be lined with foam trim which has disintegrated or rubber seals? Not sure if the foam was original or replaced something mush sturdier. The foam has been used on all the outer storage doors.
ID:	251286   Click image for larger version
Akronguy is offline   Reply With Quote
Old 10-29-2015, 11:27 AM   #2
1955 22' Safari
Laredo , Texas
I would guess rubber seals are appropriate. PO may have replaced original seals with foam.
55AS is offline   Reply With Quote
Old 10-29-2015, 11:32 AM   #3
2002 19' Bambi
Lafayette , California
The screen door on our 2002 came with foam sealing strips.
Tim
Tim A. is offline   Reply With Quote
Old 10-29-2015, 11:34 AM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
On mine foam is original. I tried to use rubber with less than satisfactory results. Removed the rubber and replaced with the proper foam from vintage trailer supply.
MICHAEL
Rubber or foam interlocking floor temporary Knudsvig Repairing/Replacing Floor &/or Frame 4 04-16-2015 05:15 AM
Do you have rubber coating on the roof? dbtolman Roof 22 03-16-2009 04:29 PM
Foam rubber seats JimS Member Introductions 9 04-13-2008 05:55 PM
Door Rubber Scaler113 Doors & Locks 2 04-27-2004 01:22 PM
Rubber Door Seal Replacement Road Ruler Doors & Locks 6 01-01-2003 08:01 PM
