Old 11-13-2007, 02:31 PM   #1
camphost's Avatar
Fixed windows on 34'
Do all 34' airstreams have 2 fixed windows on each side of the door? If so why are they fixed? We have looked at two 34' Limited Edition trailers. Both had the large windows on either side of door but they did not open.
Second question: are these windows prone to leak?
camphost
camphost is offline   Reply With Quote
Old 11-13-2007, 02:41 PM   #2
Airstreamer2's Avatar
1995 34' Limited
Glendale , California
Fixed Windows
I can't address whether all 34' have fixed windows or not. Mine '95 does. Don't know why the front roadside window is fixed. I suspect the reason the "back" one is fixed is because the door would break it should you forget to close it before opening the door completely.
Greg
Airstreamer2 is offline   Reply With Quote
Old 11-13-2007, 02:51 PM   #3
2007 25' Classic
Hydes
No, they don't. The "stacked" window which opens is an option to the right of the door. To the left of the door, over the dinette is one stacked window and a fixed window that the door opens against. Even this window can be special ordered as an opening stacked window, although Airstream does not recommend it.
craftsman is offline   Reply With Quote
Old 11-13-2007, 05:39 PM   #4
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
My ’83 has the fixed windows too. I understand why the one the door could hit doesn’t open, but am puzzled about the one that the door can’t hit. On that note, I’m still puzzled why the door opens the way it does. If it were hinged on the other side, it would blow shut if it accidentally opened while towing.
Vaughan
Old 11-13-2007, 06:13 PM   #5
GO Bob's Avatar
1982 34' Limited
1975 31' Sovereign
Grovetown , Georgia
I can give a heads up on why I think it's fixed. I had quit opening the one on my 30' because every time I did I banged it with my head. And both windows are fixed on my '82 34'.
"Humans get a lot done,not because we're smart, but because we have thumbs so we can make coffee." Flash Rosenburg
"Decaffinated coffee is the devil's blend."
GO Bob is offline   Reply With Quote
Replace/fix cruddy fixed windows? 26.982 amu Windows & Screens 3 01-01-2007 08:57 AM
Can she be fixed? Pinhead Exterior Restoration Forum 10 12-01-2005 10:25 PM
Windows-probs, Linux more prbs...back to Windows Kistler Off Topic Forum 13 11-04-2004 09:19 AM
It's Fixed! swebster Mechanics Corner - Engines, Transmission & More... 7 08-08-2003 06:00 PM
Problem fixed lbrodsky 2001 Safari 1 12-16-2002 08:42 AM
