Old 07-20-2015, 04:04 PM   #29
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
I went back to the AS in storage after work and took these photos of the rear window corner. Looks like I need to apply another bead of Parbond on these joints.
Kelvin
ID:	243537   Click image for larger version
ID:	243539   Click image for larger version
Old 11-15-2015, 08:39 AM   #30
KJRitchie's Avatar
2008 25' Classic
In preparation of resealing the top rear window I was able to remove the rear awning. Zip Dee has manuals that show the process of loosening the tension on the awning then you just unbolt the awning arms and remove two screws from the awning rail then slide out the awning.
The caulking on top of the awing rail looks a lot better than the choking on the top of the window. I'll probably start with the window first.
When up on the ladder to check the seams where the roof and the rear end caps are attached I noticed one rivet on the street side that looked fishy. See the last photo. There seems to be a hole next to the rivet. Too bad its not on the same side as my window leak. I'll have to fill it in.
Unfortunately, its too cold and windy today to start the reseal project. I need a weekend of 60F days.
Kelvin
ID:	252082   Click image for larger version
ID:	252084   Click image for larger version
Old 11-15-2015, 08:45 AM   #31
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
The solar guard hinge at the top of the front middle window was the source of a persistent window leak on my '07. That awning rail is in a similar position, so check it carefully.
2012 Dodge Durango Hemi/AWD
Old 11-15-2015, 08:53 AM   #32
KJRitchie's Avatar
2008 25' Classic
I would like to remove the clear vinyl tape between the window and the awning rail, clean everything up, reseal then apply a new tape. I can't see this vinyl tape in the Zip Dee parts list so I've sent them an email.
If I can't get this thick clear vinyl tape can anyone recommend a source?
Kelvin
Old 11-15-2015, 10:18 AM   #33
dznf0g's Avatar
Oswego , Illinois
Kelvin,
Yes those rivets are not suspicious, but definites. I have confirmed several of those in various windows as leakers. Don't be concerned with the water showing up elsewhere. It runs and travels horizontally in most unpredictable ways. There's logic to it, but you can't see the logic because of hidden structures, insulation, etc inside the walls. You have definitely found culprit (s). Maybe not all, but it is certainly a good definitive start.
-Rich-
Old 11-15-2015, 10:20 AM   #34
dznf0g's Avatar
Oswego , Illinois
You could buy an automotive clear "bra" and cut it to your dimensions
-Rich-
Old 07-31-2016, 05:50 PM   #35
KJRitchie's Avatar
2008 25' Classic
Got the trailer home today getting ready for a trip and a heavy thunderstorm rolled through. So far all the work previous in this thread hasn't fixed the issue. Not only is the original leak still there running down the rear window screen on the curb side but there is a leak running down the rear window on the street side too. I'll be getting all the roof vents resealed at the end of August so hopefully the leak will get fixed. It takes some time for the leaks to show up on the rear window so maybe its the Fantastic fan the skylight.
Can't reproduce it when I wash the trailer, needs a steady stream of water for 1/2 an hours.
Kelvin
Old 02-21-2017, 07:51 AM   #36
KJRitchie's Avatar
2008 25' Classic
Update on the rear window leak. Still not fixed.
As part of the renovation I had recently had done was to resolve the rear window leak. A&P worked on it, replaced the window gasket, left it in the rain and sprayed it down and was confident it was fixed. However, not the case after leaving it in a rain storm at my house. The leak seems to have shifted to the street side of the rear window, water drips from the interior frame onto the top of the bug screen then runs down in a couple of slow streams one above the street side latch and an inch from the vertical bug screen frame.
I had the trailer back at A&P this weekend to get a new Dometic 15k unit installed. They checked the clearance lights above the leak area and discovered the mounting screws on the clearance light were rusty. He sealed the holes, put a dab of sealant on the lens mounting screw and ran a thin bead of sealant around the base of the lens. He did this for all the rear clearance lights. Then he drilled out the awning rail rivels one by one, sealed the hole and put on a wider head rivet with sealant in each of the five mounts.
On the way home at a campground it rained heavily in the early morning and the rear window still leaked on the street side of the bug screen.
Its back at the shop for more investigation. So frustrating.
Kelvin
Old 03-21-2017, 05:04 PM   #37
KJRitchie's Avatar
2008 25' Classic
Got a call from Paul today. He was able to replicate the leak. He discovered the clearance lights on the street and center line were the culprit despite resealing the edges of the base and lens and the lens screw. He pulled the street and clearance and found evidence of leaking on the base and on the wires entering the trailer. There was rust and corrosion and the two clearance lights needed to be replaced. He will replace all three with LED versions and retest for leakage.
I'm amazed that despite sealing all these lights they still leaked. I'm going to have him check all the clearance lights.
Kelvin
Old 03-21-2017, 10:27 PM   #38
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Interesting.. our 34' has had a strange to locate leak. Each thing I change/repair moved the problem around.. front street side floor was damaged.. repaired...
So, the 'last' one I can't seem to find is on the street side near the bow.. you only find it by feeling between edge of gaucho and wall.. It has stumped me for 2 years now..
I probably need to start my own thread...
Peace and Blessings..
Channing
WBCCI# 30676
Old 03-22-2017, 05:56 AM   #39
KJRitchie's Avatar
2008 25' Classic
My leak had to be localized in the end cap assembly. After looking at the couple of Airstream assembly videos, one which showed a Classic 25fb, the leak was coming from above. Paul at A&P even used a SealTech system to try to find the leak. He discovered one from the lower part of one of the rear curved windows but didn't show up on the clearance light. He was consistently able to reproduce the leak by applying water to the lights.
Hopefully, the retest is successful.
Kelvin
Old 03-22-2017, 07:40 AM   #40
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I've been having a similar leak (same trailer as yours) since I bought the trailer 3+ years ago. I can wet the roof around the front fan with a hose spray for hours, no leak. Then a light rain with a little wind for 15 minutes would get an occasional drip in the front street side corner window.
I looked under the front street side corner light where the wire comes through the skin. I had looked at it before and there was nothing obvious to me. It was caulked solid around the wires and looked to be in good shape. I decided to remove the old and re seal it even though it looked good. When I did it was obvious that the caulk was not bonded to the skin where there was a water stain at the top edge. I resealed around the wires and all of the fasteners. It did not leak in the last rain. Problem solved, I hope!
Alan
Old 03-22-2017, 06:21 PM   #41
2016 26' Flying Cloud
Southlake , Texas
I recently removed my center rear clearance light to get power for a backup camera and it had no sealant around it. Only a thin gasket between the flat light and curved roof. The screws were already corroded and I don't know what kept the water out. I sealed around all the clearance lights and betwee the light and the base. I left the bottom side of each light unsealed just in case some water was able to get in. I hope I never have to replace a light!
2016 Flying Cloud 26u
2017 Silverado Duramax 4x4
Equalizer Hitch
Southlake, TX
WBCCI
Bgibbs is offline   Reply With Quote
Old 03-22-2017, 06:54 PM   #42
KJRitchie's Avatar
2008 25' Classic
I decided to have all my clearance lights replaced with LED versions as the current ones are all 10 years old. It will be nice to be able to leave my Airstream outside in rainy conditions again.
Kelvin
Leak then no leak. gandttimes Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 10-04-2013 01:34 PM
Our first leak Steve & Susan Leaks - Weatherstrips, Gaskets, Caulks & Sealants 18 08-16-2009 02:04 PM
Leak: Fired Up Hot Water, Now There's A Leak SSChanger Fresh Water Systems 4 07-15-2009 08:46 PM
First major leak Lothlorian Leaks - Weatherstrips, Gaskets, Caulks & Sealants 14 07-11-2008 04:28 AM
possible plumbing leak or water leak jamesl Repairing/Replacing Floor &/or Frame 1 04-06-2003 10:52 AM
