Old 01-18-2016, 04:33 PM   #1
1998 30' Excella 1000
Livingston , Texas
Finally Found The Leak!!!!!!
Finally found the troublesome leak that was showing up on my inside floor. It was not the window, not the awning arm mounts, not the rub rail and not a rivet or exposed seam.
If you look at the attached photo and note the awning rail, there is a bead of factory caulk on the end. It is a little hard to see, but it's on the top portion of the rail, the flat portion that is about one inch wide and riveted to the Airstream. A tiny gap had opened up between the edge/end of the rail and the caulk. I could not even see it. Found it by using an eyedropper to look for locations that would wick water. The other end of the awning rail also wicked in water. While it may have got inside through the underlying seam, the awning rail has a open channel on the bottom that provides a route to access the many rivets that hold it on its entire length. Make sure those ends are sealed!
As an aside, the caulk on the top of the rail, it's full length, looks good, is well bonded and does not leak. And it's 17 years old!
Siegmann is offline   Reply With Quote
Old 01-18-2016, 04:36 PM   #2
1994 30' Excella
Mississauga , Ontario
Well done Sherlock!
Al
Al and Jean
TAC ON-3
Old 01-18-2016, 04:40 PM   #3
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
Good find!
I had the same thing at the opposite end of that rail on our Avion that was causing a pretty good leak in the rear bedroom.
I know your feeling of relief from finding that!!!
PaulnGina
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
Blessed and highly favored
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
PaulnGina is offline   Reply With Quote
Old 01-18-2016, 04:47 PM   #4
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I had a similar leak from the hinge on the solar guard on the center front window. It's another spot to watch.
2012 Dodge Durango Hemi/AWD
Old 01-18-2016, 04:49 PM   #5
Bruce B's Avatar
2012 16' International
Jamestown , Rhode Island
Nice job!
Bruce B is offline   Reply With Quote
Old 01-19-2016, 10:39 AM   #6
ranchometal
2014 23' Flying Cloud
Mare Island , California
Thanks!
ranchometal is offline   Reply With Quote
Old 01-20-2016, 07:24 AM   #7
banderabob's Avatar
2008 19' Bambi
2012 23' Flying Cloud
Bandera , Texas
I've had a similar leak at the door, dripping from almost dead center at the top. We also noticed that after a good rain, the battery disconnect would not work for a while. In disconnecting it and feeling behind, found wet insulation. The battery disconnect is located about 3' directly below the leak location you describe on our unit, so I'm hoping you solved mine as well!
banderabob is offline   Reply With Quote
Old 01-20-2016, 07:46 AM   #8
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I also found leaks at that location when I purchased my trailer:
add edit: The screws holding the awning brackets were also loose. When I removed them there was no sealant on them, and obviously there never had been.
Alan
Old 01-20-2016, 08:11 AM   #9
1988 34' Excella
Stanardsville , Virginia
Thanks , you solved my problem as well that I couldn't find for the past year. I thought it was leaking at the awning supports brackets and didn't look hard enough higher up at the and the ends of the awning rails where there was a slight gap. Sealed it and now it's not leaking. Again, thank you for sharing your findings!
madpiper is offline   Reply With Quote
Old 01-20-2016, 08:27 AM   #10
Livingston , Texas
Attachment 255989
Attachment 255990
Your photos are even better than mine. And I like your toothpick pointer trick. We should all be doing that with our leak photos!
Old 01-20-2016, 09:05 AM   #11
2012 30' Classic
Homosassa , Florida
Outstanding job of finding the leak. Thanks for sharing.
Tater is offline   Reply With Quote
Old 03-01-2016, 08:01 AM   #12
la nomade's Avatar
2018 22' Sport
stanfordville , New York
i am still struggling to find where the leak near the door comes from,yesterday i caulked around the antenna, and the tv antenna..took of the cover i did put on the top of the trailer,will see what happens next time it rains ...hopefully the re-caulking done in the fall around the fan,the ac,the skylight fixed those leaks,i am then left with the leak near the door...will use tooth pick to check for open spaces along the awning etc..i can not paint the floor and put on my new floor until its all dry.
la nomade is offline   Reply With Quote
Old 03-01-2016, 10:25 AM   #13
Livingston , Texas
Don't forget to check the bottom rub rail.
Old 03-01-2016, 07:03 PM   #14
2004 30' Classic Slideout
Kerrville , Texas
Caulk
What kind of caulk do you use when re caulking? Where do you purchase it?
Thanks a lot for any info.
Richg
richg is offline   Reply With Quote
Finally found one ! Robbie R. Off Topic Forum 18 09-06-2009 07:22 AM
Finally found the leak! OregonArgy Repairing/Replacing Floor &/or Frame 4 04-04-2008 10:59 PM
Aluminum Trim Finally Found flyfshr Cabinets, Counter Tops & Furnishings 13 07-20-2006 06:24 PM
finally found the new thread button..wow crossfire Member Introductions 4 07-18-2006 04:44 PM
Finally - Found a use for the AS supplied pillows! Bambi_Bandit The Pet Forum 2 11-09-2004 09:55 AM
