Old 04-14-2008, 07:43 AM   #1
fotochop's Avatar
1969 23' Safari
New Orleans , Louisiana
Images: 18
Fan vent gasket installation
After SEARCHING endlessly for certain info here I have become a real stickler for ACCURATE TITLES OF THREADS... a thread called "leaks..more leaks" doesn't tell you much about when/where/how...but one called "help!" is admittedly worse.. I have searched, but not found...
I have new heavy duty gasket material for my metal roof fan vents:
that doesn't seem flexible enough to make into four 90 degree turns...am I correct in assuming I should cut miters and glue the four pieces down individually? thanks
fotochop is offline   Reply With Quote
Old 04-14-2008, 08:30 AM   #2
vinstream's Avatar
1962 19' Globetrotter
1963 19' Globetrotter
1961 19' Globetrotter
Wheat Ridge , Colorado
Yes that would work... The old school airplain guys would use a tourch and heat and mold them into 90* corners too... I would only attemped this if you have extra to play with... Also you want you use a High Temp Rubber Glue... You would trully be amazied how hot your roof can get in the summer months!
www.VINSTREAM.com
Wheat Ridge, Colorado
WBCCI # 1962
Instagram #Vinstream
vinstream is offline   Reply With Quote
Old 04-14-2008, 09:35 AM   #3
fotochop's Avatar
1969 23' Safari
Images: 18
thanks, vin..these didn't come with instructions...and the old ones have long since disappeared...do you know if the flat extruded edge faces OUT or in? seems like out might shed water better..
Old 12-26-2008, 09:48 AM   #4
darryl97420's Avatar
1974 Argosy 28
Coos Bay , Oregon
What type of gasket is that and where did you get it? Do you have the part number? All three of my roof vents do not seal very well and let heat out. Looks like the gasket you have could end those problems.
Darryl
darryl97420 is offline   Reply With Quote
Old 12-26-2008, 10:30 AM   #5
ronstory's Avatar
1975 23' Safari
Portland , Oregon
I'd call Inland RV down in southern CA. They seem to have everything and fast shipping on the west coast. Not alway the cheapest... as I've gotten older (note: I did not say 'more mature'. ), I'm much more willing to pay for expertise.
Ron
ronstory is offline   Reply With Quote
Old 12-26-2008, 11:37 AM   #6
Ceiling vent cover gasket
Airstream has used this ceiling vent cover gasket, since the late 60's.
http://www.inlandrv.com/catalog/images/45346.JPG
You can use it on the old metal ceiling vent covers as well, if you wish.
It is still used on the new covers today.
Andy Rogozinski
Inland RV Center
Corona, CA
Roof Vent Fan Installation jdalrymple Roof Vents, Skylights & Fans 4 11-03-2007 09:11 AM
Fan-tastic Fan Installation With Photos Dabler Roof Vents, Skylights & Fans 9 09-09-2007 08:18 PM
Gasket Material for Kitchen Fan Cover bevman Roof Vents, Skylights & Fans 1 06-28-2007 07:39 PM
Exhaust Vent Gasket Alden Miller Roof Vents, Skylights & Fans 2 08-22-2006 05:38 PM
Fan-tastic Fan installation BobbyW Roof Vents, Skylights & Fans 4 06-17-2002 09:40 PM
