Old 05-22-2011, 03:56 PM   #1
reddoor's Avatar
1965 22' Safari
LEONARD , Texas
Exterior holes?
I have yet again another question. What do you plug holes with? I've got several old screw holes up front, so we put screws with rubber washers in them. There's a larger hole where the TV wire goes in that I need to do something with. We're going to pull the antenna thing off the top and get rid of the wire. So what do I do about that hole? It's got a plastic part that the wire goes into.
reddoor is offline   Reply With Quote
Old 05-22-2011, 09:09 PM   #2
Kevin245's Avatar
Rivets are a good choice for small holes. Larger holes may require a patch.
Eleanor Roosevelt
