Old 01-11-2014, 08:28 AM   #1
ShinyPete
ShinyPete's Avatar
2014 27' Flying Cloud
Bushnell , Florida
Eternabond Tape for the roof
I have searched on Eternabond Tape (shortened EB here) use on Airforums and have seen some mention of it on a couple of threads, but I have some specific discussion points that I want your feedback on. So, I hope this is not a re-hash that becomes annoying.
Coming from the white box with rubber roof world which have lots of humps and corners that trap water, I have used EB and been pleased with it's performance. It goes over old caulk lines, seams, and screw strip lines nicely with proper preparation and patient installation. On our last RV, a 2000 Class A with Britetek roof, I used 150' of it going over every seam and caulk line and a worrisome perimeter cap to wall seam with like 159 screws in it protected only by Dicor globs. No leaks. Ever. In our 6 years with EB on the roof.
Now, we are the caretakers of Pete, a new FC27FB that I want to protect from leaks. So, here we go. I envision putting EB tape over all the caulk lines, roof panel seams, penetrations, etc., etc. Anyplace where I see caulk on the roof I want to prep it properly, apply EB white 3" or 4" tape patiently, and not have to re-caulk with Dicor, Parbond, Acryl-R, or whatever else we use up there for years. I hope. Here's the rub. If I put EB on the roof and it doesn't work like it should, what a mess to remove it. I know it sticks, believe me.
My questions here after writing this novel are "has anyone done it?" "What is your opinion on doing it on a brand new AS roof?" "Does anyone have any experience with EB tape damaging the aluminum finish or the white coating on a new AS roof?" "Any experience with it causing problems instead of preventing them?"
So, jump on in, tell me what you think! Thanks for your input in advance!
ShinyPete is offline   Reply With Quote
Old 01-11-2014, 08:31 AM   #2
dznf0g's Avatar
Oswego , Illinois
I used EB on all the roof openings when I installed my replacement skylights. It's only been a year though. So far so good.
-Rich-
Old 01-11-2014, 08:56 AM   #3
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
I have it all over on my Excella. Only one questionable spot.... but not a leak. Looks better than the globs of factory goop and with the metal backer should last forever!
Old 01-11-2014, 09:17 AM   #4
John&Vicki's Avatar
1990 25' Excella
Sisters , Oregon
I'm interested in this stuff too. I don't have experience with it, but it seems to be superior to caulk in terms of durability and appearance and I'm curious why it's not more widely used in the Airstream world. Does it have disadvantages that I've missed? Is there something about it that offends purists?
Poppy
John & Vicki
WBCCI #4291
Grown men don't need leaders. ~ Edward Abbey
John&Vicki is offline   Reply With Quote
Old 01-11-2014, 09:29 AM   #5
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
I personally find zero drawbacks
...unless you need to remove for some reason!
Simple advice is to prep the surface with acetone. Then you're gold.
Old 01-11-2014, 10:28 AM   #6
Gainesville , Florida
Used it on my Avion, stopped all the leaks now! Jim
Old 01-11-2014, 10:35 AM   #7
John&Vicki's Avatar
1990 25' Excella
Sisters , Oregon
White or gray? One best width?
Poppy
John & Vicki
WBCCI #4291
Old 01-11-2014, 10:49 AM   #8
White for the roof. About 2 inches wide? Jim
Old 01-11-2014, 10:51 AM   #9
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Looking at all the sealant on the roof it certainly makes one wonder if long term leak protection is what they have in mind.
I would also like to know if this is a good long-life product to protect the sealant that protects the seams. Or is it likely to also deteriorate and fail in a similar time as the existing sealants, just making a difficult job even worse, perhaps much worse?
Doug and Cheryl
Old 01-11-2014, 11:12 AM   #10
PA BAMBI II's Avatar
1964 17' Bambi II
Strasburg , Pennsylvania
Used EB on a Scotty
I used EB on the flat seams on my Scotty roof...I used the aluminum color so it looks great! (My Scotty is a Silverside).
I could see using the silver EB on the very top Airstream seams- those that cannot be seen by a person standing beside the trailer- but not where it could be easily seen.
As for the quality of the product, it is amazing. The previous owner told me the Scotty did not leak- it did. After trying to seal those roof seams with Proflex sealant, I went with the EB and it has been dry ever since.
Ben
"The difference between vintage and retro is that vintage is honestly old and cool. Retro tries to be but isn't."
PA BAMBI II is offline   Reply With Quote
Old 03-20-2014, 10:07 AM   #11
FishStreamer's Avatar
2007 28' International CCD
Apalachicola , Florida
Prepping roof for EternaBond RoofSeal tape
Thanks for all the great information, y'all. This topic has really peaked my interest as I will be resealing my roof soon. In the past, I've just taken my "FreeBird" to the shop to get it re-sealed, but after seeing the results, I'm confident that I can do a better job myself.
My question is how to prep for the tape application. I was hoping that I could just clean the surface of the older sealant/caulk and apply the tape over it. Do I have to remove all the old blobs of sealant first? If so, what's the best way to do that?
Thanks in advance and Best Fishes!
FishStreamer is offline   Reply With Quote
Old 03-20-2014, 10:44 AM   #12
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
I've heard that Avion owners rely heavily on this product.
Old 03-23-2014, 12:48 PM   #13
ShinyPete
ShinyPete's Avatar
Bushnell , Florida
Fishstreamer- When I put the Eternabond tape on the roof seams and penetrations of our class A, I removed any loose caulk, wiped the areas to have EB tape with Acetone (use proper safety gear and be careful ), and EB taped over the bumps, gobs, and screws per the instructions. You use a wallpaper or similar roller to "set" the adhesive properly, and that's pretty much it. I have also used this product on 3 friends' SOB roofs, and my own enclosed box trailer roof seams with great success.
I'm not an Eternabond dealer or employee, although I sound like it, I just like the product. When our Pete returns from getting his warranty punch list items addressed, I think I'll get on with this project. By the way, since I posted this originally in January, I emailed one of the tech gurus at Airstream concerning putting EB tape on the roof, and he saw no reason not to. In fact, he mentioned one of their dealers north of the border uses the product on Airstream roofs.
Thanks for keeping this thread alive, as the point of it is to ask and receive multiple opinions on the product and it's usefulness on our Airstreams!
Old 03-23-2014, 11:14 PM   #14
Thanks so much ShinyPete for your thorough and deliberate response. A scientist, like myself, truly appreciates detailed instruction. I will add that on my list to do! Thanks again and I'll let you know if I have any questions
