Old 03-31-2014, 06:56 PM   #15
reinergirl's Avatar
Hollis , New Hampshire
I'm a big fan of eternabond too, used it to seal my fantastic fans and a new maxim skylight. I also used their double stick tape.
My process is here on post # 422
http://www.airforums.com/forums/f109...ml#post1373790
reinergirl is offline   Reply With Quote
Old 04-21-2014, 11:33 AM   #16
ShinyPete
ShinyPete's Avatar
2014 27' Flying Cloud
Bushnell , Florida
Update from Shiny Pete. I finally got around to starting on the Eternabond Roof Project on our Pete yesterday afternoon. I peeled and scraped caulk gobs and EB taped the entire perimeter pf the front Fantastic Fan, and will install a Max-Air cover over it as well. I will also be doing the rear FFan the same way.
Now, I know silicone caulk when I see it, and I'm afraid JC is using white silicone on the roof now, or at least tubes full (tubes....full )of something white that is very silicone-like. Does anyone know what it is? I have reviewed the recent caulk threads, but I'm just not sure.
I peeled GOBS of the stuff from around my plumbing vents. I felt like when I was learning to solder-the bigger the glob the better the job? Not Peeling and scraping this stuff off was a job, and I think the EB tape didn't stick to the dribs and drabs that are left. EB won't stick to silicone............
Rambling here.........more later on this project.
ShinyPete is offline   Reply With Quote
Old 04-21-2014, 11:56 AM   #17
dznf0g's Avatar
Oswego , Illinois
Could be Dicor self leveling sealer.
Sent from my XT907 using Airstream Forums mobile app
-Rich-
Old 04-20-2015, 02:09 PM   #18
Soyboy's Avatar
1999 28' Excella
Frederick , Maryland
Images: 44
I used EB on my previous SOB with great success. Now that I have found a leak on right rear sided over the bed, I am going to seal that seam with EB. I don't see any obvious gaps, but the current, thinly applied sealant is starting to peel up. Mine is a '99 and likely past due for a re-seal anyway. BTW, when I did my SOB I even used some Dicor around the edges of the tape in places where it might tend to leak more than others (leading edges etc.). It seems like a great product and has wide use in the building industry, I don't know why they don't use it at the factory. Likely the cost.
1999 28' Safari
2012 F150 Platinum Max Tow 7650 GVWR 3.73 Elec. Locking Diff.(Prev 2003 Dmax).
Honda EU2000i, Equalizer Hitch
AM Solar Panels 150W - 2 Trojan T 105 6V Batteries
TAC MD-6
AIR 4534
On internet forums, please research and separate the wheat from the chaff (including mine!)
Soyboy is offline   Reply With Quote
Old 04-20-2015, 04:04 PM   #19
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
Another vote here for Eternabond. I like the Alumibond, since it's silver like the trailer. I have pictures of my project if anyone wants to see them.
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 04-20-2015, 04:08 PM   #20
dsrtgrls's Avatar
2010 19' Flying Cloud
Clarkdale , Arizona
ok
eb will stick to dicor as it is not silicone based. i have used it on my roof seams and hope it will work as expected. prep it well, follow directions, take your time, get help with the job if another set of hands will be better. nothing is perfect or 100% but i feel this will do the job for my trailer at least at this point. i am 62 and not eager to get up on the roof to caulk much but will. good luck with the eb. i am rooting for all who use it.
dsrtgrls is offline   Reply With Quote
