Old 10-18-2014, 05:16 AM   #1
2000 30' Excella
Toledo , Ohio
Entry door seal ?
I need to replace the seal on my entry door on my 1985 Airstream all I can find is a seal offered by different venders that looks smaller than mine and is self adhesive . Mine is glued on and looks much thicker . Has anybody replaced theirs with the newer seal ? Out of Doors mart , Vintage, and Inland all show the same part . I live in Ohio and store it outside and it's getting cold don't have much more good weather to do this and want to do it right .
Les Grace
woodfox45 is offline   Reply With Quote
Old 10-18-2014, 06:21 AM   #2
Les Grace
The larger gasket is available, that comes from Airstream.
The double sided tape is not used as such.
Adhesive is applied to it and the door.
After about 5 minutes or so, the gasket is installed, with the seam at the bottom of the door. Then adhesive is applied to both seams and pushed together. That in effect gives you a seamless gasket.
Thousands of owners have used this type gasket, so don't worry about it, as it is the correct one.
Old 10-18-2014, 07:18 PM   #3
2000 30' Excella
Toledo , Ohio
Thanks Andy for the reply ; The seal I have I got from Airstream and it is the one with the self adhesive and it's much smaller as I said than mine and i'm afraid to use it .
Old 10-18-2014, 09:46 PM   #4
How about a photo along with the gasket dimensions.
I can then ID it for you.
Old 10-19-2014, 10:17 AM   #5
2000 30' Excella
Toledo , Ohio
Andy : I can't figure out how to add a photo on here can you send me an email address ?
Thanks : Les
Old 10-19-2014, 10:26 AM   #6
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Don't use the quick reply. Select reply then look for the paper clip at the top. Click it.
Old 10-19-2014, 11:09 AM   #7
janeinthemtns
1985 31' Excella
near Chama , New Mexico
I just replaced the door gasket on my 85 Excella. I got it from Vintage. The adhesive on the gasket doesn't work worth a darn. It was too easy to pull the whole thing off and use black adhesive on it. Still waiting for a good rain to check for leaks.
janeinthemtns is offline   Reply With Quote
Old 10-19-2014, 03:09 PM   #8
crestonrv's Avatar
1948 16' Wee Wind
1964 26' Overlander
2007 19' Bambi
crossville , Tennessee
if still leaks after new seal is properly installed door may need to be tuned.
bent to fit , check for play at top/bottom with pressure on center . if rocks top/bottom door is probably a little sprung.
crestonrv is offline   Reply With Quote
Old 10-19-2014, 03:15 PM   #9
You can leave the white tape in place, and simply add the black adhesive to it, as well as on the door. Then after 5 minutes or so, install the gasket on the door.
That's how we have instructed our customers for years, and as of today, not single failure.
Old 10-19-2014, 05:40 PM   #10
terrencecolp's Avatar
1976 25' Tradewind
Tulsa , Oklahoma
I've found that if the trailer is not properly leveled, the door won't fit square.
terrencecolp is offline   Reply With Quote
Old 10-19-2014, 05:48 PM   #11
That is not true, within reason, if the door was installed correctly.
It is true, however, if the trailer is put into a twist.
Old 10-20-2014, 09:56 AM   #12
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
anytime I have a gasket or seal with pre-adhesive, I add 3M Trim Seal to the gasket and the area it is to be stuck to. Works great.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 11-11-2018, 08:19 AM   #13
1976 25' Tradewind
1998 34' Cutter Bus w/slide
Overland Park , Kansas
Could anyone post a photo of the product installed? I’m about to tackle the same task and want to make sure I’m orienting and applying this properly.
Cheers
Ppleasants is offline   Reply With Quote
Old 11-18-2018, 10:37 AM   #14
1976 25' Tradewind
Anyone? Hoping to tackle this ASAP but what I’m reading seems to go against what I’m seeing in execution, specifically on my original weatherstripping
Installing exterior lights-to seal or not to seal Belegedhel Lights - Interior & Exterior 7 10-26-2013 07:14 AM
1964 door in a Door entry door hinges recycled Windows, Doors, Locks & Vents 1 09-18-2013 06:07 PM
To 'seal' or not to 'seal'?? b8sfamily Floor Finishes 6 03-31-2009 06:13 AM
Vertical lip seal and trim seal for Classic Motorhomes rdm General Motorhome Topics 16 05-22-2006 07:49 PM
