Originally Posted by Norm1234 Ok, I just got a chance to check out the door closer. The door and the frame are in good shape. However the top of the door does not seal very well. The bottem fits snug but the top is kind of lose. I look for adjustments but did not find any, are there any kinds of shims I can put in the top hang to make it seal better? |
If the door at the top is not sealing correctly, that says that the door frame is bent.
The door sheet metal should exactly match the side sheet metal, like it was one piece.
Place a ruler parallel to the ground, near the top of the door, at one side and then the other side. Does it touch the window sheet? If not, then the door frame is warped.
If it does touch the side sheet, then there is a probglem with the gasket.
