Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Leaks - Weatherstrips, Gaskets, Caulks & Sealants
Old 10-06-2009, 11:23 AM   #1
Profile:  1973 25' Tradewind
Chatham , Ontario
Door gasket on '73 Tradewind.
I need to order gasket material for all the windows and the doors (outer, & screen) for our '73 Tradewind.
I have searched and seem to find lots of threads concerning trailers from the '60s, but nothing for our year. I apologize if I have simply missed this info.
Do I use the same gasket on both doors on this trailer?
Thanks in advance.
Loris
Airstream Project Picture Gallery
http://lorisart.org/gallery/thumbnails.php?album=34
BossCamper is offline   Reply With Quote
Old 10-06-2009, 12:26 PM   #2
Chatham , Ontario
Never mind. I went on Inland RV pages and found my answer.
Old 10-06-2009, 02:14 PM   #3
tphan's Avatar
Profile:  1972 27' Overlander
estes park , Colorado
You may benefit from doing a little comparative shopping at both VintageAirstream, and OutofDoorsMart. You have to get the glue too.
tphan is offline   Reply With Quote
Old 10-06-2009, 02:34 PM   #4
Profile:  1968 24' Tradewind
Oxford, , Mississippi
Don't go overboard on the adhesive. The sticky on the back of the new weather stripping is excellent and if you properly clean the surface you will not need any except maybe at the corners and very top edges. Cleaning the surface is the key. If you don't do that, buy lot of weatherstrip adhesive. I replaced all window and door seals on my 68 TW. After a lot of trial and error found the way to get the old adhesive off the gasket surfaces was to use a Dremel tool with a scotchbrite buff. Lowes and HD have them. Removes all the old stuff without scraping and without having to use acetone or lacquer thinner.
Old 10-06-2009, 02:42 PM   #5
Chatham , Ontario
Thanks for the cleaning and adhesive tips
I'll probably be getting the gaskets from a nearby AS dealer. Their price(s) are not so much more as to warrant me paying for the shipping, and I can get it sooner.
I just had to get an idea of what I was looking for.
Thanks for the thought.
Loris
Old 10-06-2009, 04:15 PM   #6
Commercial Vendor
Profile:  Corona , California
Loris
We use the super weatherstrip black adhesive, since it does a one time permanent job of holding gaskets in place.
The 3M yellow adhesive, doesn't do the job, at all.
To depend on the self adhesive on the back side of the triangular gasket for the entrance door and access door gasket, is not wise. Get the trailer in hot weather and watch it fall off. Simply opening and closing the entrance door, will make it fall off.
We believe that when we do a job for a customer, that we should do it the best than can be done, the first time.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 10-06-2009, 04:51 PM   #7
Chatham , Ontario
I agree .. if it is worth doing, it is worth doing right.
53 door gasket pinktrailer Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 07-03-2009 05:59 AM
'63 Door Gasket dieseleagle Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 06-16-2009 06:04 AM
door gasket Sjean Doors & Locks 25 06-09-2009 03:06 PM
Which door does gasket go on? 63air Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 05-18-2009 01:02 PM
Gasket on door or inside of door? beckybillrae Leaks - Weatherstrips, Gaskets, Caulks & Sealants 14 07-06-2007 02:06 PM
