Old 07-05-2010, 08:33 PM   #1
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
door gasket in proper position?
This pic shows where my gasket is on the door currently.Should the bottom piece be attached higher? It doesn't look right.The sill pic is included.The bottom door gasket sits below the rivets when door is closed.
Name:	(4 of 9).jpg
ID:	106335   Click image for larger version
Name:	(5 of 9).jpg
bwaysteve is offline   Reply With Quote
Old 07-05-2010, 10:04 PM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
I think it is OK. It looks like the gasket will compress on the flat plate area below those rivets...giving a good seal.
Missed you guys at the fire works last night. The polishing continues....
Old 07-05-2010, 11:12 PM   #3
That gasket was used on 64 and older trailers, not 65's.
The door gasket should completely seal from any exterior water, or even air, prohibiting either one from entering the coach.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 07-06-2010, 11:10 PM   #4
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
still not sure on placement
Andy,
Awhile back I had Inland send me all the correct gaskets and 3m adhesive to do all windows,access doors,and entry door.
I am not sure exactly where the bottom of the gasket should go.Flush around like the sides or lower where it is in the pic.
On the sill there is a recess that looks like maybe it should go there.Thanks,Steve
PS on the windows I have your instructions on installing the D gasket.Do I also remove the old bulb gasket?
Which door does gasket go on? 63air Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 05-18-2009 12:02 PM
Window Guard Gasket Position pyanke Rock Guards, Segment & Window Protectors 4 07-23-2008 12:19 PM
Gasket on door or inside of door? Becky B. Leaks - Weatherstrips, Gaskets, Caulks & Sealants 14 07-06-2007 01:06 PM
proper bulb for large door light? IPM General Motorhome Topics 3 03-19-2006 06:27 AM
