Old 06-20-2013, 08:20 AM   #1
Tdcraw's Avatar
Yukon , Oklahoma
Door gasket
Just installed my new door gasket from odmrv and boy is the door tight. How long tell it limbers up as I'm not sure kids could close it.
Tdcraw is offline   Reply With Quote
Old 06-20-2013, 10:17 AM   #2
DryFly's Avatar
1972 Argosy 20
Snoqualmie , Washington
Modern gasket materials don't really "limber up". Eventually the man-made rubber gets brittle and cracks. Are you sure you have the correct gasket? Sounds to me like they may have sent too thick of a gasket for your door.
DryFly is offline   Reply With Quote
Old 06-20-2013, 11:07 AM   #3
The correct entrance door gasket is triangular shaped.
Spraying it with "silicone spray" will help the door close a little easier.
While your at it, also spray the door lock striker plate and striker bolt.
Old 06-20-2013, 03:53 PM   #4
Tdcraw's Avatar
Yukon , Oklahoma
Yes it is the right one, triangle shape. Just checked it and the heat of the day seems to be helping it buy will add the spray as well
Old 08-03-2013, 05:14 PM   #5
1973 31' Sovereign
tampa , Florida
looking for a supplier for the door and window gaskets.....thanks..
kjterz is offline   Reply With Quote
Old 08-21-2013, 05:35 AM   #6
Geezer
1991 25' Excella
Sapulpa , Oklahoma
try inland rv "Andy Rogowski". I got mine there.
LRPorter is offline   Reply With Quote
Old 08-21-2013, 05:44 AM   #7
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
You can get it at the same place the OP got his door gasket.
