Old 11-06-2006, 12:07 AM   #1
Petethefeet's Avatar
1964 30' Sovereign
1959 22' Flying Cloud
1957 26' Overlander
Raglan , New Zealand
Images: 14
Does anyone have any tips on removing silicone?
Hi, I have just put the body of my 64' soveregn back onto the restored chassis, am currently stripping flashings and rails etc. to prep for exterior work. I am wondering if anyone can help me with any info on removing excessive amounts of silicone that has been left around penetrations and skylights. At the moment, I am using acetone and a synthetic scotchpad and truckloads of elbow grease! I'm in New Zealand, so brand names may not correspond here. Any help appreciated.
Regards,
Pete the feet.
Petethefeet is offline   Reply With Quote
Old 11-06-2006, 01:10 AM   #2
Fyrzowt's Avatar
West of Fort Worth , Texas
Images: 8
I'm at work right now and can't give you any specifics, but I was in the A/S dealership this week and they had a silicone removal product in there. I don't know anything about it, it just caught my eye on the shelf. Hopefully someone else can be more help.
Dave
Fyrzowt is offline   Reply With Quote
Old 11-06-2006, 09:04 AM   #3
Mel
Mel's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Pete the feet, I have no experience with this product, but noticed it as I was browsing through the site the other day. Perhaps a similar item is available in New Zealand?
By the way, welcome to the forums!
Mel
Mel is offline   Reply With Quote
Old 11-06-2006, 09:15 AM   #4
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
The Dow-Corning site used to state there was "no known solvent for silicone" but at the hardware store on Saturday I saw a tube of silicone remover - maybe they've changed the formulations like they had to w/ superglue so it wouldn't poison the surfaces forever, it may help get it out of the surface pores, etc.. The remover may work similar to a cleaning product called dirtex that has surfacants strong enough to cause auto windshield rear-view mirrors glue to fail and fall off a day or two after washing windshield with it, so maybe applying it or another industrial strength detergent will help it seperate if you have a few days to let it work.
I've never tried the remover, I use the cured bead against itself to try and get it to peel off cleanly - once you razor blade it the thin remaining residue seems extra gnarly. Rubbing off remaining traces works for me but I've never tackled dozens of feet of silicone slug slime...
Old 11-06-2006, 09:26 AM   #5
Mel
Mel's Avatar
1967 22' Safari
1960 Caravel
One more tip...
Forgot to mention, beer also helps the situation.
A PO gunked a lot of silicone all over the windows and around the vents of our Caravel, and I used a plastic razor blade to pull up the big chunks. Gasket remover dabbed on a rag and held on the silicone seemed to loosen it a bit as well.
Mel
Old 11-06-2006, 12:20 PM   #6
1964 30' Sovereign
1957 26' Overlander
Images: 14
Thankyou all so much for your helpful suggestions to date, I think I'll start with the cold beer option (just kidding!), from time to time, I do purchase products from the U.S. so if I cannot find a corresponding product here, I may get suggested silicone removers imported, although with any luck that part of the job will be finished by then. Thanks again.
Regards,
Pete.
Old 11-06-2006, 02:30 PM   #7
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
We used Permatex Gasket Remover and lots of sharpened popsicle sticks & rags to get all the old silicone off ours. Seemed to work pretty well but still a nasty job I don't want to go through again ~
Shari
RMVAC | WBCCI DenCO Unit | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 11-06-2006, 04:20 PM   #8
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I have been told that charcoal lighter fluid will crumble the silicone. I haven't given it a try yet, but if it works I am all for it. I have a citrus based solvent that will, eventually soften the silicone. It is just as hard on the clear coat as gasket remover.
Aaron
WBCCI #XXXX AIR #2495
Old 11-06-2006, 06:15 PM   #9
InsideOut's Avatar
1956 22' Safari
Images: 108
Aaron
Yes, the gasket remover will probably strip the clearcoat too...but we were doing that anyways.
Shari
Old 11-06-2006, 07:40 PM   #10
Baton Rouge , Louisiana
Images: 42
Pete,
I had the same problem in areas of my Sovereign. I asked a body shop about it and the suggested a pin stripe remover wheel. It's made by 3M and is basically a round rubber eraser wheel that mounts to a 3/8" chuck drill. You get it going and gently touch it to the silicone. The wheel heats the silicone up and the tackiness of the wheel just pulls it off. Worked great for me and only cost $10 or so and seems to last forever. Just my .02 man.
-Don
cobra93 is offline   Reply With Quote
Quicky Hints and Tips FrankR General Repair Forum 7 10-05-2012 11:09 PM
removing Dometic Refrigerator smily Refrigerators 16 08-18-2010 04:36 AM
Removing the body shell and installing new floor completely - any one done this? williamhenshall Repairing/Replacing Floor &/or Frame 11 03-13-2006 12:21 PM
Removing wallpaper from 76 tradewind Rennegarbe1 Upholstery, Blinds, Walls & Interior Finishes 4 02-05-2003 05:52 AM
Removing the Armstrong AC unit FrankR Furnaces, Heaters, Fireplaces & Air Conditioning 11 08-02-2002 12:10 PM
