Old 04-03-2011, 05:51 PM   #1
2001 19' Bambi
Orange Park , Florida
Do It Yourself Pressure Test
Hey Kids:
I was wondering if I could rig a do it yourself pressure test on my 2001 19 foot Bambi.
Leak near door wicking under curbside dinette. Solid plywood floor, only small patch of top layer soft, will repair with marine epoxy, no wood needs to be replaced, thank God!
Door seals around sill, though they need replacing, are dry as a bone.
Have to check the rock guard bracket, and entry light. If not those then will continue working my way up slowly with hose to midline moldings and above.
Was considering making a plywood cover for the escape window hatch and capturing it inside with two plywood strips secured with long carriage bolts and wingnuts through the cover and strips, to sandwich the window frame. Then I plan to cut a hole in the plywood cover to admit a blower supported on sawhorses- I am thinking carpet dryer - but how powerful should the blower be?
Too weak might not show leaks, too strong might cause them.
Has anyone tried this? I would appreciate any suggestions.
(I had an AC pan leak two years back thru a crack in the front of the shroud. Water was entering there and pooling in the front of the AC pan, sitting directly up against the main cool air duct and thence leaking past it into the trailer. It ran along a beam around both sides of the trailer and showed up behind the door in front of the pantry and on the floor just to the left of the galley. Hose method found it, got a new shroud, sealed the dam seperating the front of the pan from the back, no problems since. Also fixed a crack in the drip channel that was letting water ht the floor and may have been the culprit behind the leak that showed up left of the galley.)
cauchy is offline   Reply With Quote
Old 04-03-2011, 06:17 PM   #2
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
Sealtech 430R
The proper piece of equipment for this task is a "Sealtech 430R". I have one at my shop & it works great. If you google "Sealtech", I believe their website has a list of RV shops that have their equipment. This will be much better than trying to reinvent the wheel.
Colin
Colin H is offline   Reply With Quote
Old 04-03-2011, 06:18 PM   #3
soldiermedic's Avatar
Florissant , USA
I agree with Colin. I use a Sealtech 430R for all my pressure tests. The 14" impeller provides enough airflow to properly do the test even on a small Bambi.
Steve
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Old 04-03-2011, 06:37 PM   #4
Ottawa , ON
Yes, I see it. And only $2,950! Well, gotta rush out and get myself one of Those! (not!)
Old 04-03-2011, 06:58 PM   #5
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
That is a bit high, even for a club. The website lists all sorts of places that use it. (There's even one in New Mexico!)
Lynn
WBCCI 21043
Old 04-03-2011, 07:00 PM   #6
Colin H's Avatar
1959 28' Ambassador
1949 24' Limited
Peru , New York
can you spell EBAY
Colin
Old 04-03-2011, 07:05 PM   #7
Florissant , USA
Nor did I pay retail price. Jeff from Sealtech called me with a used one he repo-d!
Old 04-03-2011, 07:41 PM   #8
2001 19' Bambi
DIY Leak Test
Wow.
I have checked with dealers around here and all want 250-300 for the test, not the resealing, just the test.
May wind up paying it; I may have to. But if I can buy/rent a blower and try it out it may save a few $$$.
I am looking at a Harbor Freight blower now with a rectangular output duct, for $44. Perhaps $20 on the sawhorses and 2 hours to put it together.
If it works, bully for me and I have an apparatus that I can re-use yearly.
If it doesn't work, then I am out $64 but have a blower that I can use to dry the still-existing leaks.
Will let you know in the next few weeks.
Old 04-03-2011, 07:43 PM   #9
Florissant , USA
Wow..that's a pretty hefty price for the service. Of course overhead is factored in I am sure. I am about a third of that at rally events.
Steve
Old 04-03-2011, 08:05 PM   #10
Colin H's Avatar
1959 28' Ambassador
1949 24' Limited
Peru , New York
Originally Posted by cauchy View Post
Wow.
Wow, I just charge my usual hourly rate, & depending on the number of leaks, it can take about 1-1 1/2 hours.
Colin
pressure test
Another Water Pressure Question lsmith Fresh Water Systems 3 04-03-2011 09:20 PM
Tire pressure for 390 XL jwitwer Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 5 03-07-2011 03:44 PM
Tire pressure GAT Tires 5 02-07-2011 02:36 PM
Correct Tire Pressure on Tow Vehicle Jim Pona Tow Vehicles 4 02-01-2011 10:37 AM
Discovered how to increase water pressure! HCR Fresh Water Systems 6 01-15-2011 01:50 PM
