Old 12-24-2008, 03:51 AM   #15
imeynstein's Avatar
Texarkana , Arkansas
Does Lowe's or Home Depot carry Acrylic-R??? I am limited as to what I can get considering where I live....It seems that everything I need has tons of shipping and handling on top of the cost.....errrrrr.....Boo hoo.....
imeynstein
imeynstein is offline   Reply With Quote
Old 12-24-2008, 05:57 AM   #16
Cyclist
henw's Avatar
2007 28' International CCD
Windermere , Florida
I think it's a good idea to check all the seams a couple of times/yr. I also crawl underneath to remove any rust twice/yr.
Tom
2007 28' Int CCD.
2011 F 250 Big Honking Diesel
DTV 5lnb on a tripod.
Wilson wired repeater with YAG.
Two big screens
15dB Backfire WiFi antenna and WaveMagnum
Centramatics.
Hawkshead Tire Monitors.
henw is offline   Reply With Quote
Old 01-05-2009, 02:01 PM   #17
WK57ABF's Avatar
2007 25' Classic
kendal , cumbria, UK
Took this photo this morning. Been below freezing at nights for 2-3 weeks here and this stuff oozes out during cold weather - looks like gorilla snot!
Same thing happened last winter. It leaks out in various spots below the belt line and out of the chrome trim. Although it is sticky, it can be washed off with rv cleaner.
I suppose if it keeps leaking out it will need replacing at some time - anyone know what it is?
Thanks, John
WK57ABF is offline   Reply With Quote
Old 01-05-2009, 02:30 PM   #18
2015 23' FB International
2007 19' International CCD
Steamboat Springs , Colorado
Julie,
Could you post the schedule for all of us to look at? Also, could you include the winterizatin and storage information?
Many thanks,
Steamy1 is offline   Reply With Quote
Old 01-05-2009, 05:55 PM   #19
zamboni's Avatar
1939 to...
Is it possible that someone used a steel rivet to install/repair your "chrome trim"?
zamboni is offline   Reply With Quote
Old 01-05-2009, 08:08 PM   #20
CanoeStream's Avatar
St. Cloud , Minnesota
Tim, I found plenty of OEM steel core pop rivets in both rubrail & beltline installation on my '74 Argosy. Wishes were fishes and all that .. if they ran out I'm sure they ran up the street to the local ACE to get them by the next few days.
5 meter Langford Nahanni
Old 01-05-2009, 09:06 PM   #21
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
Thanks, John
So it is sticky? Like an adhesive? Airstream used an adhesive on the chrome trim that is now oozing out when the weather is cold? Cold contraction must be allowing it to slip out. If this is the case, others will need to comment on how to address it.
"I've got aluminum fever, and the only prescription, is more AIRSTREAM!!!"
'64 Safari Resoration Blog ("May"):
http://ts8501.blogspot.com/
TAC MN-6
WBCCI/VAC 11736
AIR 25979
ts8501 is offline   Reply With Quote
Old 01-05-2009, 09:08 PM   #22
ronstory's Avatar
1975 23' Safari
Portland , Oregon
Heck, nowadays.... even harbor freight carries aluminum rivets. Steel bad.
Ron
ronstory is offline   Reply With Quote
Old 01-05-2009, 10:09 PM   #23
Community Organizer
Guido's Avatar
2005 22' Safari
South Chicago , Illinois
...Money?...
Fr. Guido
"We have just religion enough to make us hate, but not enough to make us love one another." Jonathan Swift
Guido is offline   Reply With Quote
Old 01-06-2009, 02:06 PM   #24
WK57ABF's Avatar
2007 25' Classic
Thanks folks.
The chrome trim on door hinges fixed with grey butyl type stuff (had them off to tighten bolts), but have never taken trim off belt line. Marks definitely not rust - sticky goo.
We're full timers therefore inside 70 degress F - outside freezing. So a temperature thing could be causing the "gorilla snot" to leak out, as suggested.
John
Old 01-06-2009, 05:26 PM   #25
soldiermedic's Avatar
Florissant , USA
When I pressure test an airstream many people want to use the Trempro Vulkem. It works great, but can be a bit messy and it's pretty tough to lay a really thin bead unless using a syringe. When I tested my trailer in the nice 60 degrees we had last weekend, I used parbond in thicker gaps needing sealing, but used acryl-r on the seams and thin areas.
My trailer was tested back in February and there were many leaks found and sealed at that time. Over the 2008 travel season we towed several thousand miles. The shaking and vibrating of moving down the roads likely opened up a few more leaks.
I think checking and resealing yearly is not necessary, but gives the owner piece of mind, especially if the unit is stored outdoors and uncovered.
Steve
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
