Old 02-22-2013, 11:30 PM   #1
1988 32' Excella
29 palms , California
Dent repair/re-seal
I have an 88 Excella. A tree fell on the back prior to my purchasing it, so there is some damage that I need to repair. There is a leak somewhere back there, either due to the tree damage or the fault seal at the floor level where the rear bumper meets the shell. At this year is it typical to start seeing leaks in the seams? If so then I would like to replace the rivets and re-seal everything. If that is the case, then what order would be best? repair the dents (hammer out), then reseal and re-rivet, or opposite? The damage is around the rear window frame as well so Im not sure what kind of damage/repair is required around there.
Timbojr is offline   Reply With Quote
Old 02-23-2013, 06:05 AM   #2
Photo's ??
Andy Rogozinski
Inland RV Center
Corona, CA
Old 03-29-2013, 10:57 AM   #3
outofcontrol's Avatar
1996 28' Excella
Portland , Oregon
Yes, pictures would help a lot. Hard to give advice about it without really seeing the damage. From what you said, I'm imagining everything from a football dent, to massive tree damage.
-Kevin
Hopefully it's not this bad:
1996 Airstream Excella 28'
2007 GMC Duramax 4x4 CCSB
outofcontrol is offline   Reply With Quote
Old 03-29-2013, 12:29 PM   #4
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
WOW. Look at all the damage that trailer did to the tree !!!!!!!! Should never have planted it there.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
