Old 07-21-2013, 08:38 PM   #1
1999 25' Safari
Somewhere , Ohio
Curved Seams
Our Bubble has curved seams on the exterior end caps. I was told the curved seams should never leak due to the fact that they are interlocking with the next seam.
If this is so, do I still use sealant on them?
By the way, the other skins have the lapped seams.
Thanks.
Deb
Air Cruiser is offline   Reply With Quote
Old 07-21-2013, 08:49 PM   #2
reinergirl's Avatar
Hollis , New Hampshire
What? Heck yes they leak, at least mine do! I sealed inside and will do outside as well?
reinergirl is offline   Reply With Quote
Old 07-21-2013, 08:50 PM   #3
reinergirl's Avatar
What do you mean by " interlocking"?
Old 07-21-2013, 08:52 PM   #4
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
I'm curious what you mean by "interlocking." There are fairly complex sheet metal seams that lock the metal together with a complicated bend-and-fold (such as a Pittsburgh seam). Airstream seams are typically just two sheets with an overlap that is riveted together. They absolutely leak, which is why AS goops them up on the inside, and runs a bead of sealant along the edge from the outside.
My understanding is that aircraft panels are epoxied along the seams as ell as riveted. Many folks of questioned why AS seams don't have a glue/sealant in the seam itself.
Old 07-21-2013, 08:57 PM   #5
1999 25' Safari
Somewhere , Ohio
Hi Shelly! Wow, you're quick, thanks!
Our exterior end caps, on the bottom of each seam, are rounded and I was told the top of the next seam down has been rounded in the opposite direction, and they slide together.
Do you have Hehr windows? Our Hehr windows sort of do this to fit together as a hinge at the top. Hope I'm making sense.
Does your Overlander have flat, overlapped end caps, or are they rounded out and curve in at the bottom? I have no idea what models and/or years they did this on.
It's only on the exterior end caps that are made this way, all of the rest of the skin seams are flat and overlap.
Deb
Old 07-21-2013, 09:01 PM   #6
1999 25' Safari
Somewhere , Ohio
Hi Belegedhel!
I'm not familiar with a "Pittsburgh seam", but it sounds as though it might be that. Are you familiar with how the '50's Hehr windows fit together at the top for a hinge? I picture that it must be that way on these seams too.
If they do have the "Pittsburgh seam", would they leak, do you think?
Thanks.
Deb
Old 07-21-2013, 09:08 PM   #7
reinergirl's Avatar
My endcaps are the basic overlap, no rounded edge..... Interesting I didn't know they did a " hinge type" seam. Can you show us a picture? Theoretically I don't see why that makes them leak proof, horizontal seams like hehr windows I can see it but with a vertical seam water would just run down the seam to the bottom ..... Hmmmmm... Awaiting pictures
Old 07-21-2013, 09:19 PM   #8
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
seal the seams, seal the seams, seal the seams......
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 07-21-2013, 09:37 PM   #9
1999 25' Safari
Somewhere , Ohio
I have been trying to download a pic from our memory card to our computer so I could then download it here, but I can't seem to figure it out -- this is a new all-in-one, it didn't come with a booklet, so I went to the web and it doesn't say how to do this, just says how to print a picture for a paper copy.
Becky, you're right, just seal the seams.
I'll try to get the pic downloaded tomorrow so you can see what they look like.
Deb
Old 07-21-2013, 10:06 PM   #10
pbearsailor's Avatar
Port Hadlock , Washington
I have the rolled edge on my 13 panel '57, but that is all it is, just a rolled edge. The panels overlap and leak like everyone says.
-steve
Forum Thread: First She Had to Take a Ride on a Boat
Blog: My 57 Caravanner
pbearsailor is offline   Reply With Quote
Old 07-22-2013, 08:16 AM   #11
Belegedhel's Avatar
Houston , Texas
I doubt if it is a Pittsburgh seam, as that is a very convoluted seam--was just throwing it out as an example. A picture would help, but nonetheless, I would recommend sealing the seam, interlocking or not.
Old 07-22-2013, 11:35 AM   #12
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up I actually....
......prefer the Pittsburgh Salad.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 07-22-2013, 07:19 PM   #13
1999 25' Safari
Somewhere , Ohio
Thanks to everyone for sharing your knowledge and ideas.
I am going to try to download two pics of our endcaps; one hopefully will have part of a flat seam as well as the curved seam for comparison. I tried to download these a couple of hours ago, but its cloudy today, and our Verizon Jetpack doesn't seem to be getting through.
Thanks again.
Deb
Well, I was able to get one of them this time, but not the one with the comparison, however, you can see that the seams are curved.
Old 07-22-2013, 07:22 PM   #14
1999 25' Safari
Somewhere , Ohio
Trying the other pic, I think it is a little more of a closeup too.
Deb
(Must have been a break in the clouds. Yes, this one definitely gives a closer look.)
