Old 09-26-2017, 02:55 PM   #1
1995 30' Excella
Harper Woods , Michigan
Convert permanently fixed skylight into removeable one as a roof access hatch?
Hello,
I've removed the 18" x 26" bathroom skylight from my '94 28' Excella Classic for refurbishment/recaulking/ resealing, and I think I would like to convert it to a hinged skylight that can be removed. Aside from ventilation, I could use it as an access hatch to the roof for inspection of the other roof penetration fittings. Has anybody done this already?
Bob Blarney is offline   Reply With Quote
Old 09-26-2017, 04:16 PM   #2
Obviously-NOT
james.mileur's Avatar
Kalispell , Montana
Originally Posted by Bob Blarney View Post
Hello,
Hi Bob,
are you thinking about a bunkbed style ladder? I'm not sure if they sell step stools/ladders narrow enough for the hallway and tall enough to get you up enough for topside inspection. Guess you could make your own and stow?
James
James Mileur, HY80-2-Al,
2017 Classic Twin, 2016 RAM 3500 Megacab, ProPride hitch
james.mileur is offline   Reply With Quote
Old 09-26-2017, 09:47 PM   #3
1979 23' Safari
Wayland , New York
I like the idea. It'll just take some engineering and fab work to make it happen.
Old 09-26-2017, 10:18 PM   #4
dznf0g's Avatar
Oswego , Illinois
There was a member who installed a boat hatch for just your reason several yeares ago. I do not remember who it was, but search on skylights or maxim threads. Maybe you'll hit it.
-Rich-
Old 09-27-2017, 07:47 AM   #5
1995 30' Excella
Originally Posted by james.mileur View Post
Hi Bob,
James
At the moment I'm able to use a stepladder so that my waist is just below the opening and I'm able to reach both the bath vent and stack vent that I'm replacing, as well as clean up and tape the skylight flange. I haven't figured out about how I would refurbish the A/C seal/caulking
An 8-10ft telescoping ladder would probably be excellent. But for now I have an extension ladder that could be separated and I think it's narrow enough to fit the opening.
Old 09-27-2017, 11:39 AM   #6
Muscle Shoals , Alabama
If you were using a high quality skylight like the Maxim (aluminum frame) you should be able to make it work.
mschneid is offline   Reply With Quote
Old 09-27-2017, 11:53 AM   #7
Well, now.
This kind of idea is why I keep checking this site. Thanks for this, I am not ready to start any action in this direction at this point, but I do love the thought. And I appreciate the input from those with more experience, to help clarify which clever ideas are maybe a bit beyond the edge, which could be done if certain issues are taken into account, and which are straightforward, based on the accumulated knowledge.
Thanks everyone.
dower.bill is offline   Reply With Quote
Old 09-29-2017, 12:21 PM   #8
1995 30' Excella
After giving this some more thought, I have developed some ideas.
There is a white PVC trim board made for exterior house trim, and it may be suitable for the rectangular frame. The frame will fit over the existing roof flange, and have an EDPM weather seal on the bottom edge where it rests on the roof.
The corners could be solvent welded with plumbers' cement. A question will be the amount of expansion and contraction of the PVC material with temperature changes, so that the glazing does not pop off or crack due to mechanical stress.
The glazing will be a plastic, either acrylic or polycarbonate. I believe that it's thin enough to form an arch that sheds water, so then the next question is how to fasten it to the frame. There are double-sided tapes with very high bonding characteristics such as the 3M VHB series, but I'll need to consider whether a tape seal could hold things together under all conditions. I suppose that for added insurance, I could drill a few oversized holes for screws, and use stainless steel screws with neoprene sealing washers underneath.
Old 09-29-2017, 01:22 PM   #9
DavidsonOverlander's Avatar
1964 26' Overlander
Milton , ON
I would be looking at building with aluminum rather than PVC. It will be longer lasting and will hold fasteners better. There is a wide range of extruded aluminum available to work with, and you might even get by with easy-to-find aluminum angle. It might involve welding at the corners, but if you have everything ready to go the cost to do that should be minimal. I would also sandwich the polycarbonate between layers of aluminum with a good sealant rather than relying on the sealant (or sealant and screws) alone.
Grant Davidson
Milton, ON
1946 Spartan Manor
1954 Va-Ka-Shun-Ette
1964 Overlander
1965 Avion C-10 Truck Camper
1974 Sovereign
2005 F-350 SRW 4x4 crew cab long box
TAC ON-5
DavidsonOverlander is offline   Reply With Quote
Old 09-29-2017, 05:04 PM   #10
1995 30' Excella
I think aluminum presents its own set of issues with fabrication. The range of commonly available sizes of material is small, and there is still the problem of expansion and contraction. So far as holding fasteners goes, I'm not convinced that that is an important issue for this purpose.
The PVC material for house trim is engineered to perform and hold fasteners (e.g. pocket screws) like wooden trim for many years, and solvent-welding PVC is easily achieved in home shops. Moreover, it is easy to cut and finish to a desired shape with common woodworking power and hand tools.
Old 09-29-2017, 05:15 PM   #11
65CV's Avatar
Western , Massachusetts
For a couple of ideas from the boating world, search westmarine.com for Lewmar Hatch and Nicro Solar Vent.
I have an older trailer with a removable Astradome. I'm making a "storage cover" that will have the Nigro Vent installed -- storing the trailer for a couple months in Arizona this year and want to get some heat out! Also good for removing moisture.
65CV is offline   Reply With Quote
Old 10-04-2017, 06:32 PM   #12
1995 30' Excella
Yea, measure not once, nor twice, but thrice...
I'd made some initial notes as I was working on the roof, and then I made some 'careful' measurements with a tape measure. Well, when it came down to cutting the material today, I thought it might be a good idea to check again.
I used two carpenter squares to bracket the existing flange, and then discovered that the flange had been racked into a rhomboid parallelogram when it was installed. it's about a 2 degree out of square on the corners. If I had made the hatch to my original measurements, it certainly would not have fit. It's no wonder that the original cover and interior garnish/trim are so oversized! They compensate for the poor workmanship.
Old 10-06-2017, 04:05 PM   #13
1995 30' Excella
Made from 3.5" x 96" PVC fascia trim board, acrylic sheet, 3M Outdoor Permanent Mounting Tape, stainless steel screws with neoprene sealing washers for insurance. It still needs weatherstrippong on the bottom and latches to hold it down tight, and also neat finish work of the interior frame, but it's watertight for sure. The frame was glued and pocket-screwed, and the holes in the acrylic were drilled oversize with a pointy 1/4" ceramic tile bit since a bit for plastic wasn't available.
ID:	296388   Click image for larger version
ID:	296390   Click image for larger version
Old 10-17-2017, 03:32 PM   #14
1995 30' Excella
The skylight hatch has proven to be weatherproof through some heavy wind & rain without being dogged down tight while the AS is parked. It's very nice to look up and see the clouds go by. As soon I'm done getting some other things done in prep for the Fall and Winter, I'll work out the details on the latches and then trim out the inside for beauty.
skylight gasket, velcro residue on skylight glass basecamper Base Camp 0 06-11-2016 10:52 AM
Remove one battery permanently tailpipe Electrical - Systems, Generators, Batteries & Solar 13 03-05-2013 08:51 AM
a Hatch, I want a hatch snkrichards General Repair Forum 4 05-17-2012 09:56 PM
Replace fixed shore line with removeable pickerdd Electrical - Systems, Generators, Batteries & Solar 3 10-12-2009 02:39 PM
