Common leaks, sealing from the exterior
I recently acquired a ‘57 Caravanner. It definitely leaks. There is some floor rot around the edges of the trailer, and in the photo attached you can see where it has run down the wall in the closet.
The interior is in pretty great condition for the year, and so I’m planning to clean it up and keep using it for a few more years before a total makeover.
Since I’m not taking the interior panels out, is it possible too seal these leaks from the outside that won’t leave residue that will look bad when I polish the trailer? How would you seal leaks from the exterior?
Also, where are the most common leaking areas? That will give me a place to start.
