Old 06-25-2013, 03:54 PM   #1
1997 25' Excella
Waterville , Minnesota
Cleanup of Acryl-r
Just received a can of acryl-r and the dispensing pump, my question is how does a person clean up the pump after cleanup or do you leave it on the can till the next use. No directions came with it, please help.
Bait guy is offline   Reply With Quote
Old 06-25-2013, 04:18 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Lacquer thinner, denatured alcohol, leave it in can and put wire loop into tip. Put in ziplock bag and store in cool
Dark place
Peace and Blessings..
Channing
WBCCI# 30676
Old 06-25-2013, 04:24 PM   #3
1997 25' Excella
Thanks for the quick reply. My only issue is I received a 16oz can of this stuff, I will most likely be buried with the excess. I would never use this amount in a lifetime, I dont believe.
Old 06-25-2013, 04:25 PM   #4
Baltimore , Maryland
It thins with xylene. Once dry, it cleans off with lacquer thinner as Channing said. try not to play with it too much when applying.
Old 06-25-2013, 04:35 PM   #5
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Yeah you want it thin enough that it will wick into seam but not so loose to drip.
Channing
WBCCI# 30676
Old 06-25-2013, 07:16 PM   #6
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Here is the Data Sheet for it. It says to clean up with Xylene, Tolulene, or MEK. make sure and wear safety glasses and chemically resistant gloves when using any of those.
Aaron
WBCCI #XXXX AIR #2495
Old 06-25-2013, 08:51 PM   #7
dscluchfc's Avatar
1984 31' Excella
Abernathy , Texas
Where did you buy the can if Acryl-R?
David
TAC # TX-18
AIR # 410
http://www.flickr.com/photos/dsphotoscapes
dscluchfc is offline   Reply With Quote
Old 06-25-2013, 10:08 PM   #8
SilverGate's Avatar
2007 23' Safari SE
San Diego , California
I bought my can of Acryl-R from Airstream, Inc.
My first can of Acryl-R with applicator also came front Airstream, Inc.
SilverGate is offline   Reply With Quote
Old 06-26-2013, 04:21 AM   #9
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Be warned about MEK it is very nasty stuff. If possible don't use or be around it .... Too many people I know can trace physical problems to use of it.
But it is good stuff, man...far out !
Channing
WBCCI# 30676
Old 06-26-2013, 04:36 AM   #10
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
They have a new formula... got ours here.
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 06-26-2013, 06:04 AM   #11
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
I wife off the end of the applicator gun with lacquer thinner and stick a small wire in the tip. No problems with storage.
When I caulk the trailer I tape the joint, caulk the seam, dip a finger (use blue nitrile glove) mineral spirits and strike the joint and immediately pull the tape.
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 06-26-2013, 08:21 AM   #12
1997 25' Excella
I bought my acryl-r from "Out of Doors Mart"
Old 06-26-2013, 02:28 PM   #13
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
Dunno if that is a "new" formula or a different formula... On the Schnee-Morehead/ITW website that number is listed under metal building sealant versus the SM5514 which is listed under Recreational Vehicle sealants. SM5514 is listed as low VOC, which makes me wary. I have not had good luck with low VOC stuff in a lot of applications.
Aaron
