Old 12-11-2012, 01:45 AM   #15
cuyeda's Avatar
Long Beach , California
If only the PL polyurethane roof flashing came in a gray color. I called tech support if this came in a gray color. The answer was no. There is a concrete crack and masonry gray, but it has a some sort of grit mixed in with it.
IMHO, I would use a blue painters tape around the edges before applying the caulking. Then use a rubber scraper used for caulking edges in the bathroom and kitchen applications. After excess caulking is removed and cured a little, remove the painters tape for a cleaner application.
1947 Curtis Wright
1958 Traveler 18'
cuyeda is offline   Reply With Quote
Old 12-11-2012, 04:54 AM   #16
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up In my experience......
............the Sika 721 UV is grey and will work as well as the PL.
note....there is a gasket between the BT vent flange and the roof.
Old 12-11-2012, 09:08 AM   #17
cuyeda's Avatar
Good point about the black gasket. I should have stated "if only it came in gray for sealing all other trim pieces without gaskets". I wish Sika was sold at the big box stores. :-)
1947 Curtis Wright
1958 Traveler 18'
