Old 10-07-2013, 05:21 PM   #1
1976 31' Sovereign
Sandpoint , Idaho
Cleaning Old Adhesives?
Hi there,
I'm working on putting things back together again after a shell-off renovation.
What is the best way to remove all the old adhesives and sealants from the aluminum? I'd like to make my own mess rather than just add to someone else's mess.
I don't know exactly what was used on this AS but I do find what looks like clear silicon of the sort often see on aquariums. I also have all of the factory installed sealants to clean up.
Suggestions?
Pete
phoyt is offline   Reply With Quote
Old 10-07-2013, 06:02 PM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Is not affecting the clear coat a factor?
For silicone I cut off as much as possible with a sharp, razor type blade and then use silicone remover.
Old 10-07-2013, 06:17 PM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Mineral Spirits
3M PrepSol
Brakleen
Plastic putty knife, wooden paint stirring sticks, nitrile gloves, and plenty of rags.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 10-08-2013, 08:08 AM   #4
Lumatic's Avatar
1993 34' Excella
Images: 16
A heat gun may help
Old 05-15-2018, 07:35 AM   #5
Falmouth , Maine
OK - assuming we get all the adhesives off the aluminum, what do we use to re-adhere? The carpet has come loose off the aluminum walls in places and the vinyl header trim on the inside of the main door has come loose. Behind it were multiple failed attempts to adhere. Most stuck to the aluminum; none of them stuck to the vinyl. What was supposed to be used? HELP!!!!
joeeagle66 is offline   Reply With Quote
Old 05-15-2018, 07:41 AM   #6
dznf0g's Avatar
Oswego , Illinois
Originally Posted by ROBERT CROSS View Post
Mineral Spirits
3M PrepSol
Brakleen
What Bob said X2.
-Rich-
Old 05-15-2018, 07:45 AM   #7
dznf0g's Avatar
Oswego , Illinois
Sagging vinyl headliner? If so, re-gluing doesn't work. Some have used an upholstery tucking technique. Use search function and use sagging headliner, or sagging vinyl.
Carpet (mouse fur???) should be able to be re-glued. I'd try some 3M headliner adhesive. Automotive 3M product.
-Rich-
Old 05-15-2018, 11:54 AM   #8
Falmouth , Maine
The part I'm having the most problem with is the vinyl trim over the interior side of the main door. It was loose, so I removed it, but after seeing what everyone else tried unsuccessfully, I'd like to know how it's supposed to be done!
Old 05-15-2018, 02:26 PM   #9
dznf0g's Avatar
Oswego , Illinois
Maybe a pic. Don't even know what trailer you have, let alone the piece you're trying to describe.
-Rich-
Old 05-16-2018, 02:14 PM   #10
Falmouth , Maine
Vinyl door trim
2003 Bambi. Here are a couple of photos of the piece.
ID:	311128   Click image for larger version
