Old 07-29-2007, 06:57 AM   #1
Denis4x4's Avatar
Durango , Colorado
City Water fitting/leak below
I have a steady dripping leak directly under the city water inlet. Any thoughts or ideas?
Denis4x4 is offline   Reply With Quote
Old 07-29-2007, 08:10 AM   #2
2005 34' Classic
Richmond , Virginia
Mine just started leaking too. I have an access panel that you unscrew. You probably have the pex line with a screw on fitting that screws to the backside of the inlet. I just tightened mine and it solved the leak.
Resorts is offline   Reply With Quote
Old 07-29-2007, 10:17 AM   #3
AirConditioner's Avatar
Mabe just a rubber washer?
One suggestion. Is this leaking in plain sight, right out of the rear of the fitting?? Might just be a bad rubber/neoprene hose washer in the fitting. If it's leaking from the pan, it might be an overpressure condition that your street water pressure regulator isn't handling - above 45-55 lbs/in.
AirConditioner is offline   Reply With Quote
Old 07-29-2007, 10:23 AM   #4
clancy_boy's Avatar
2003 22' International CCD
1966 17' Caravel
Kiln , Mississippi
Images: 8
I had this 2 weeks ago and thought the same thing. Water was coming from just below the outside connection out the wheel well. I took my access panel off below the kitchen sink to look at the fitting. It was fine. My flex hose to my bathroom sink was leaking at the hand wand and since it ws in the holder at the sink it leaked onto the subfloor under the sink just in front of the outside fitting. My method for diagnosing this was to disconnect the city hose and preasurise the system with the trailer pump - still had a leak so I dug further and found the sink flex hose to me my problem - new hose solved it.
Mike
Michael, Tina & Layla BZ
1966 17' CARAVEL LUCY
2003 22' INTERNATIONAL CCD DESI
Old 07-29-2007, 10:45 AM   #5
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
If its directly underneath, it sounds like a simple washer will do the trick. Change that out and see what happens.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 08-24-2007, 07:07 AM   #6
Denis4x4's Avatar
Durango , Colorado
"Mine just started leaking too. I have an access panel that you unscrew. You probably have the pex line with a screw on fitting that screws to the backside of the inlet. I just tightened mine and it solved the leak."
Finally got around to attacking the problem and it was as simple as tightening the fitting on the backside of the inlet.
Old 08-24-2007, 08:45 AM   #7
wbrownrr's Avatar
2002 22' International CCD
San Luis Obispo , California
Interesting... My CCD has just developed a similar leak...a drip, actually.... and you've given me a couple of ideas as to where to begin diagnosing the problem. Thanks!
Wayne
2002 22' CCD
2008 Dodge Ram 1500 5.7L Hemi
wbrownrr is offline   Reply With Quote
Old 08-24-2007, 08:55 AM   #8
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Had this happen on my Classic when it was new. It ended up to be a loose fitting next to the water heater. It was a matter of just tightening things up.
Jack
Jack Canavera
STL Mo.
AIR #56
'04 Classic 30' S.O.,'03 GMC Savana 2500,'08 Vespa GTS 250
Old 08-24-2007, 09:05 AM   #9
richinny's Avatar
2011 34' Classic
thanks for posting the solution. while i like the tv show, i don't like unsolved Airstream stories!
Ricky
Old 10-22-2007, 05:25 AM   #10
1992 34' Excella
Punta Gorda, , Florida
inside city water inlet
We had a leak on our city water inlet. The sick smell of mildew was our only alert as the inlet is inside a night stand. Very seldom go in there for anything except maybe our weapon. There was a fine mist spraying from a pinhole which made for a very soggy carpet. Being 6'2 and weighing in at 230#s I had one heck of a time getting to this tight area. Why share this story? I'ts wise to check this from time to time for those of you that own a 34'. The weapon was SS so a good clean up did the trick. A fan placed just outside of the door dried up the carpet but I was afraid to check under it. Hope this never happens to any of you. Check it out. If your pump cycles off and on while having the city water turned off, you just might have a leak.
FlaAirstream is offline   Reply With Quote
travelling w/out water system maznblu Fresh Water Systems 6 09-09-2002 12:03 PM
city water inlet valve failure? JohnGalt48 Fresh Water Systems 2 08-01-2002 04:43 PM
Water Drip uwe Fresh Water Systems 6 07-11-2002 08:39 AM
City water 53flyingcloud Fresh Water Systems 2 07-11-2002 12:08 AM
Replace copper water lines in '61 Bambi 61BambiCanada Fresh Water Systems 1 05-22-2002 06:04 AM
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
