Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Leaks - Weatherstrips, Gaskets, Caulks & Sealants
Old 09-12-2005, 05:01 AM   #1
Lee Davis
Profile:  1986 34' Limited
Prospect , Tennessee
Chemical Prep Before Caulking?
I read a thread which said that you should do some chemical preparation or cleaning before caulking. I just bought a few tubes of Vulkem 636 to repair a window leak and caulk the top of the Belly band and wondered what type of prep top do other than washing the area. Any suggestions would be appreciated
Lee
Full Time.....keeping the shiny side up
Lee Davis is offline   Reply With Quote
Old 09-12-2005, 05:13 AM   #2
TomW
TomW's Avatar
Profile:  1967 26' Overlander
Normal , Alabama
Images: 77
For Vulkem or Parbond, I just washed the area with soap & water before use taking care to rinse thoroughly. Timing helps - wash in the morning, and caulk in the afternoon to let any water which may have seeped into the joint-to-be-caulked evaporate.
Before gluing new window seals on, I wiped the area with acetone before gluing.
Tom
Caulking and Sealants (silicone, parbond, vulkem & more) Chuck Leaks - Weatherstrips, Gaskets, Caulks & Sealants 201 10-19-2008 02:34 PM
Caulking Kistler Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 04-19-2003 01:32 PM
Sealing Windows & Caulking outside mgordon Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 01-13-2003 01:18 PM
Furnace Exhause Plate Caulking niftypkg Furnaces, Heaters, Fireplaces & Air Conditioning 2 08-23-2002 08:32 PM
caulking ALANSD Leaks - Weatherstrips, Gaskets, Caulks & Sealants 7 07-10-2002 03:13 AM
