08-01-2015, 09:40 PM
1977 31' Excella 500
Bonnyville
, Alberta
Caulking Under Patch
Hey guys, I have a few exterior patches. What is the best caulking for under the patch and in the Olympic rivet holes?
08-01-2015, 09:49 PM
1995 25' Excella
xxxxx
, xxxxxx
Parabond will do fine for either.
08-02-2015, 04:52 AM
1964 17' Bambi II
Schererville
, Indiana
I like Tempro. I use it for most repairs/sealant.
Becky
1964 Bambi II
1988 Avion 32S
08-02-2015, 06:21 AM
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View
I am with Becky. Tempro 636 .
08-02-2015, 09:15 AM
2000 25' Safari
Davidson County
, NC Highlands County, FL
TremPro 635 is what Out of Doors Mart sells. That's what I have used for several years. ODM advertises that it is recommended by Airstream.
TremPro 635 Polyurethane Sealant 360002 [360002] - $7.59 : Out-of-Doors Mart!, More Airstream Parts on-line than anyone!
TremPro is also available at Fastenal.
Some people like 636 because it has a slower cure rate, therefore a longer working time and slightly better adhesion. This would be beneficial when working on larger panels.
DO NOT use silicone caulk.
Alan
08-08-2015, 12:50 PM
1967 26' Overlander
Golden
What will happen if you use silicone?
08-08-2015, 05:51 PM
2000 25' Safari
Davidson County
The first time silicone caulk is used to re-caulk it most likely will do the job, depending on the preparation.
The next time re-caulking is needed no caulk will stick to silicone. It is very difficult to remove if you need to re-caulk. Some people have gone as far a grinding the metal to get the residue off.
Some people will argue that silicone caulk is warrantied for XX number of years. That is true the caulk will last forever, but the bond to what ever the caulk is put onto is not warrantied. When (not if) the bond breaks and comes loose it is difficult to fix it.
add edit: I have heard some people say there is a reaction between silicone caulk and aluminum, but I do not know if that is valid.
Alan
08-08-2015, 06:35 PM
1977 Argosy 24
Milltown
, Wisconsin
I used Parabond on my Argosy, and after 2 years it is hard as a rock and cracks and can be picked off with your finger. As far as I am concerned it is way over rated as a sealer for Airstreams. I live in Wisconsin so it is not being baked in the sun to make it hard, it's just a bad product.
08-09-2015, 12:53 PM
1964 17' Bambi II
Schererville
, Indiana
I agree, ventport!
Becky
1964 Bambi II
1988 Avion 32S
