Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Leaks - Weatherstrips, Gaskets, Caulks & Sealants
Old 12-06-2003, 05:36 AM   #29
john hd
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
this may not work for you....
when replacing some sewer vents on a buddys trailer i used a brass wire wheel chucked in a drill.
takes all traces of vulkem right off! and everything else. it leaves a nice burnished surface.
obviously, this will not work if you are trying to save the clear coat. the wire wheel is better suited for areas that don't show or in preperation before polishing.
i also used it to clean the vulkem from the tops of windows before resealing.
john
you call them ferrets, i call them weasels.
Old 12-06-2003, 06:07 AM   #30
Dwight
Dwight's Avatar
Profile:  1999 34' Excella
Joshua , Texas
Try Hoppe's No. 9 Solvent. It works extremely well and you can get it at Wal-Mart as well.
Dwight is offline   Reply With Quote
Old 12-06-2003, 08:40 AM   #31
j54mark
Profile:
Mineral spirits (paint thinner) will work, albeit slowly. Use a craft stick sharpened like a chisel to speed removal.
Mark
Old 12-06-2003, 09:00 AM   #32
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 40
How about a tiny brass wire wheel in a Dremel type tool?
Uwe
Old 12-06-2003, 09:44 AM   #33
Sneakinup
Master Riveter
Sneakinup's Avatar
Profile:  1972 27' Overlander
. , Mobile-- as in transient
Images: 72
I removed mine with a wire wheel in my RotoZip tool. It worked great, with a few cautions. WEAR GOGGLES!!! Also, the Vulkem gets heated and flies all over the place, then cools, and is tough to remove from everything. In addition, the wire wheels tend to disintegrate quickly. At $3+ each, it adds up quickly.
Other than that... it does work well.
1972 27' Overlander 72 Overlander
Jack Pad--- A notebook used by Jack Nicholson in the Shining to keep track of how much work he had done on his Airstream. "All work and no polishing makes Jack's Airstream a dull trailer"
Sneakinup is offline   Reply With Quote
Old 12-29-2003, 03:19 PM   #34
Sue&Von
Profile:
Silicone Salty ??????
We are beginning to research sealants in our own plodding way. There is so much on this subject to plow through.
As well as finding where to buy the products we choose finally.
Lots is here lots probably over at VAC list or whatever they changed it to, and probably lots at all other Airstream sites.
Then there are the manufacturers sites etc.
Gonna check with wholesale suppliers and glass companies and anyone else I can find.
Von seems to remember a body shop pro telling him years ago that silicone contained sodium (SALT that is) and for that reason it should never be used on metal. We don't know if that is accurate or not, but it stuck in Von's mind all these years. Do any of you know?
What if any knowledge does anyone have regarding applying heat ....flame or hot air to the old existing sealants to help with removal. We of course can appreciate the Safety risks. It is the removal data we seek.
TYIA
$&V
Sue&Von is offline   Reply With Quote
Old 12-29-2003, 05:07 PM   #35
ALANSD
GA Airstreamer Air_005
Profile:  North , Georgia
Vulkem stays soft? I used it around trim work on my motorhome a year or so ago. It has gotten dirty looking , and seems to hold onto black moldy tree stuff that is hard to get off.
I also used the "aluminum sealant" from HD around some windows, and it is still silver and shiny. So whats wrong with the aluminum stuff?
Looks good to me for trim work, although I would use the Vulkem for larger apps like around the TV antenna, etc.
Rallys twice a year..Lots of fun, food, and aluminum.
http://groups.yahoo.com/group/gaairstreamcampers/
http://airstreampassion.blogspot.com/
My Music Site:
HTTP://ALANDAVIDSONGS.COM
ALANSD is online now   Reply With Quote
Old 12-29-2003, 06:50 PM   #36
Davydd
Davydd's Avatar
Profile:  Tonka Bay
Images: 13
Thumbs up Silicone Sealant with Metal
We use silicone construction sealants for metal to metal contact all the time. Generally it is used with sheetmetal, aluminum entrance frames, glazings, etc. I never heard of salt being an ingredient of silicone sealant or silicone being a detriment to metal. Metal is what it is primarily used for.
Davydd
Pleasure-Way Plateau Sprinter B Camper Van
2004 Nissan Titan LE Crew Cab
(Former vintage Airstream Owner)
http://www.tonkawoods.com
http://www.porktenderloinsandwich.com
Davydd is offline   Reply With Quote
Old 12-29-2003, 06:55 PM   #37
Davydd
Davydd's Avatar
Profile:  Tonka Bay
Images: 13
Sez who?
I forgot. You might want to ask on what authority? OK, I am an architect registered in 11 states, a certified construction specifier, and responsible for architectural document production and quality assurance for about 3 billion dollars of construction per year. I better be right in what I said or I am in big trouble.
Besides, the American Institute of Architects' Masterspec documentation backs me up.
Davydd
Old 12-29-2003, 07:03 PM   #38
wahoonc
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
I was always taught not to use silicone and silicone base caulkings on mill finish aluminum because of the acetic acid. I work with architectural metals and NONE of our manufacturer's recomend or specify silicone caulk. Butyl, Polyurethane, Terpolymer, Rubber but not silicone. From what I have observed in the field, silicone does not adhere well to very many smooth surfaces, just got done peeling about 5 tubes worth of silicone off of the windows of my AS, considering the fact that I used my finger nail to pick at it and it just peels right off, I don't think it adheres well at all to smooth surfaces.
Aaron
Old 12-29-2003, 07:41 PM   #39
aviontt
aviontt's Avatar
Profile:  , Connecticut
Well this just gets more difficult every day I'm watching this thread to get some info but I keep getting bushwacked...What is the best stuff ? and what is the best way to apply it ? HEEEELLLLP !!!!!
Worry will never change the outcome!!!
aviontt is offline   Reply With Quote
Old 12-29-2003, 07:50 PM   #40
wahoonc
Rivet Monster
wahoonc's Avatar
1980 31' Excella II
Images: 35
aviontt,
The two types of caulk reccomended by AS are the Vulkem and Parabond, as far as the application use common sense as well as trial and error
Aaron
Old 12-29-2003, 09:34 PM   #41
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
It has been said before but bears repeating.
Use Parr Bond for small seams and joints 1/8th inch and under, Vulcem for every thing else. You can use the Vulcem for the small seams but you will need to transfer it to a disposable medical syringe to get that small of a point on it. Also the Parr Bond is thin enough that it will wick into the seam where the Vulcem will just fill it.
Sometimes it is an issue of gap size and the amount you want to seal. I have and use both. I am one of those owners that has a the least an unopened tube of Vulcem on hand as well and a tube of the Parr Bond going. If you don't use all of the Vulcem wrap it tightly, especially the tip and store it in the refer. It will last for months. Non of it is really expensive I get it all locally for 5-6 bucks a tube.
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 12-29-2003, 10:01 PM   #42
davidz71
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
Parr Bond colors
I mentioned in a post within the last year or so that Parr Bond in the 5 oz. tube comes in silver, white and clear. The RV company I stopped by only had white and clear on the shelf so I picked up a tube of clear. I will probably order the silver from Inland RV in the spring when I get back to polishing the trailer. I had planned on sealing the top seams with clear and the horizontal rub rails and windows with the silver.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Sealants??? JAD Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 04-15-2004 09:33 AM
Floor cancer smily Repairing/Replacing Floor &/or Frame 15 10-13-2003 12:11 PM
