Old 11-05-2011, 05:19 PM   #1
Ridgerunner3's Avatar
2002 25' Safari
Fountain Inn , South Carolina
Images: 13
Caulking Around '02 Safari Black Hehr Windows
I plan to caulk around the outside frame edge of the black Hehr windows on my 02 Safari. I plan to use black 221 Silkaflex.
In the past I have noticed that some SOB's do not apply caulk completely across the bottom edge of the frame. I assume that this is to allow drainage of any condensation in the frame. Should I seal the window frames all the way around or leave a un-caulked strip along the bottom edge of the frame.
Thanks for any help.
Bud
Ridgerunner3 is offline   Reply With Quote
Old 11-06-2011, 06:52 PM   #2
2002 25' Safari
Images: 13
Just bumping this back up to see if anyone knows "Should I seal the window frames all the way around or leave a un-caulked strip along the bottom edge of the frame".
Thanks in advance for any insights or experience with this.
Bud
Old 11-08-2011, 11:19 AM   #3
Bud
That depends on any possible present leaks.
If none from the windows, then seal the 2 sides and the top.
Black Water Flush Blocked ElliotA Plumbing - Systems & Fixtures 9 09-10-2018 10:36 PM
Our '56 Safari (aka Our Retirement Home) SafariSteve 1956 Safari 41 09-04-2013 06:55 PM
New '67 Safari black water tank? losfew Waste Systems, Tanks & Totes 1 09-06-2011 07:19 PM
Safari :: 2006 Airstream Safari SE Mrs Silverback Airstream Registry Discussions 0 08-19-2011 09:31 AM
2003 safari - how do you remove black water tank? greenrvlife Waste Systems, Tanks & Totes 3 04-08-2011 11:15 PM
