Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Leaks - Weatherstrips, Gaskets, Caulks & Sealants
Old 07-16-2002, 03:30 PM   #1
Chuck
Sad Moderator
Chuck's Avatar
Profile:  1973 23' Safari
Images: 99
Lightbulb Caulking and Sealants (silicone, parbond, vulkem & more)
perusing through the threads, I'm wondering: should I pro-actively seal all the seams on my "new" ('73) trailer, or just large gaps or known leaks? (there aren't any that I know of...yet, except perhaps a sloppy sillicon job around the front window). I'm reading that vulkem needs to be run in a rather thick bead....I can't imagine how that would look running up and down the trailer (yuck). Or is there some method for getting it into the seams, making it more or less invisible?
What is this "par-bond" stuff, and where do I get it?
what about the alluminum gutter/flashing caulk available at HD?
Chuck is online now   Reply With Quote
Old 07-16-2002, 06:28 PM   #2
airstreamcaravel
airstreamcaravel's Avatar
Profile:
It "seems" to be a problem
Ditto! I have the same question. Anyone have some good proven techniques?
What is the best product?
airstreamcaravel is offline   Reply With Quote
Old 07-16-2002, 07:19 PM   #3
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Vulkem is used for the large seams, such as at the top of the windows, entrance door, vent cover flanges and awning rail. It's also used to seal the vent pipe gaskets, through the fiberglass screening and on to the black vent pipes.
Parbond, comes in 5 ounce tubes and is used for small seams, such as segment seams and around the top and both sides of clearance lights, and around the sides of the window frames. It, like vulkem, never completely hardens. Very small beads can easily be made with Parbond.
We have used it for many years and keep much of it in inventory.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Inland RV Center, In is online now   Reply With Quote
Old 07-16-2002, 08:03 PM   #4
PeterH-79MH
PeterH-79MH's Avatar
Profile:
Images: 63
If you want your seams and windows look like this read on.
Once you figure out how to do it,
the instructions actually make sense.
_____________________________________
WBCCI Member at Large
PeterH-79MH is offline   Reply With Quote
Old 07-16-2002, 08:07 PM   #5
PeterH-79MH
Profile:
Images: 63
get some 3M blue tape, 1" and 1 1/2".
On straight seams, place 2 strips leaving about 1/16" space, on corners place a piece of 1 1/2" tape and cut it with an Olfa type knife.
Old 07-16-2002, 08:16 PM   #6
PeterH-79MH
Profile:
Images: 63
carefully remove the side on the skin and place it 1/16" from the frame for a perfect fit.
I personally like Tremco's (same co that makes vulkem) Dymonic Polyurethane Sealant. It sticks like thunder to aluminum and clearcoat and never dries hard. It is more liquid than vulkem and not so gritty. The color is a grey/aluminum. I bought it at the local glass company for $5.25 for a 11 oz tube. After forcing it into the seam using a caulk gun, I use a rag with paint thinner to smooth it out prior to removing the tape.
Old 07-16-2002, 08:35 PM   #7
airstreamcaravel
Profile:
I'm all caulked up! Oohh haaa yaa!
PeterH,
That technique rocks! The product sounds interesting, I'll give it a try.
RVAndy,
As always, may god bless and keep you in our circle.
Dave
Old 07-16-2002, 08:54 PM   #8
InsideOut
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
Thumbs up
I'll store this thread away for later...
Thanks Andy for the clarification on the different sealers...and thanks to PeterH for the technique tip! Love it!
Shari
InsideOut is online now   Reply With Quote
Old 07-16-2002, 09:20 PM   #9
davidz71
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
I've also heard that Alcoa Gutter Seal works like the Parbond. Anyone been able to compare the difference between these two products?
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 07-17-2002, 12:44 PM   #10
Chuck
Sad Moderator
Chuck's Avatar
Images: 99
Thanks, guys, this is great info. But my original question: should I just go ahead and "do" all the seams in the trailer, just for good measure?
Old 07-17-2002, 01:16 PM   #11
Commercial Vendor
Chuck. If the seams are not leaking, don't. However, if it will make you feel better, then go for it. The vast majority of exterior seams are sealed for cosmetic purposes, the exception being the roof and awning rail.
Inlandrv.com
800-8777311
Old 07-17-2002, 01:17 PM   #12
Andy R
Administrator
Andy R's Avatar
Profile:  1961 16' Bambi
Dallas , Texas
Images: 13
Thanking members for their posts...
Please dont forget to use the Karma button to give members who post great content more points. There is also a field for comments where you can leave more praise. This will allow the archive to stay "on topic" with less post to sift through when looking for specific content.
Cheers,
AIR # 2 - 1961 Bambi - Jeep Cherokee
Campground Reviews: Submit and review campgrounds around the US
Andy R is offline   Reply With Quote
Old 07-23-2002, 08:23 AM   #13
64GT
64GT's Avatar
Profile:
Inland Andy - 1 more time for the blond!
I saw a post of your's not long ago that said caulking the seams was useless but sold a lot of vulkem. So in the post above are you saying 'yes' to sealing the seams on the roof (but not the sides).
64GT is offline   Reply With Quote
Old 07-23-2002, 09:44 AM   #14
Commercial Vendor
Seam sealing
Sealing the seams on the side of a coach, is usually cosmetic. If indeed there was a water leak on the side, it would indicated severe abuse or structural damage. Sealing the roof is another matter. Since the roofs receive far more sun exposure than the sides, a failure of a sealer can occur. It is wise to check the roof periodically for a sealed area that may have opened up.
Generally speaking, the vast "majority" of Airstream water leaks are caused by the owner. Simply not balancing the running gear properly, AND, not keeping it that way, causes at least 98 percent of all water leaks. Extremely rough roads, cause the rest. Rarely, will anyone ever find or hear of an Airstream trailer, that has been parked for years, having a rain water leak.
That in it self tells where the problem starts.
On the other hand, most water leaks, in fact, are not at any seams, but are most likely from worn out window gaskets, sewer and drain line vent pipe gaskets that are cracked ( these should be replaced every 5 years or so), leaky clearance lights (caused by simple sun exposure which shrinks the plastic), bad or missing ceiling vent cover gaskets, and of course, missing rivets.
Awning rails usually take a beating, when the awning has been used for extended periods of time. Notice how a small wind makes an awning flutter, let alone high winds. That fabric movement puts a great stain on the awning rail.
Any resealing should be carefully considered, before any application of a sealer. If there are no leaks, then leave it alone.
Like they say, "if it ain't broke, don't fix it."
inlandrv.com
airstreamparts.com
Inlandrv.com
800-8777311
Sealants??? JAD Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 04-15-2004 09:33 AM
Floor cancer smily Repairing/Replacing Floor &/or Frame 15 10-13-2003 12:11 PM
