Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Leaks - Weatherstrips, Gaskets, Caulks & Sealants
Old 09-19-2008, 11:36 AM   #1
Profile:  1975 31' Sovereign
Durango , Colorado
PeterH's window caulking technique
Okay, I just got my Vulkem from Andy. I am ready to try PeterH's technique on my Vista View windows. Question: Can I use thinner and a rag like Peter did with the Vulkem?
bbmombo is offline   Reply With Quote
Old 09-19-2008, 05:01 PM   #2
76sovereign's Avatar
Profile:  1976 31' Sovereign
ozark , Missouri
Has anyone tried a product called NP1
Has anyone tried a product called NP1. It comes in Aluminum color and I was told by the business I was at they used to carry Vulkem but they replaced Vulkem with this NP1. Sounds like a line to me . . .but I bought some just in case.
http://airstreamremodel.blogspot.com
http://vimeo.com/kani
76' 31' Sovereign
76sovereign is offline   Reply With Quote
Old 10-19-2008, 02:34 PM   #3
Wardinbb's Avatar
Profile:  1964 24' Tradewind
Big Bear Lake , California
Hoppes #9 Blast & Clean Barrel Cleaner
Let me chime in here and say that this stuff should be in the Airstream Bible for cleaning up vulkem sealer. This stuff will liquify fresh sealant and loosen old. This product was brought to my attention by another Forum member some years ago and he is right, it can not be beat.
Now some folks feel environmental concerns outway the use of this product as it is a strong solvent, so be it, you are entitled to do as you wish.
I am a firm believer in vulkem as I have removed areas of the stuff that was 40+ years old and still pliable and doing it's job. Other areas that were subject to extreme exposure were not so soft but nothing a plastic scraper couldn't handle. I've used Parbond and all I can say is that it features a small nozzel. Vulkem, coupled with the Hoppes, can not be beat. Use of a small syringe or a large one with a big needle will get you wherever you what to go. Yes the vulkem is messy. But with a pair(s) of disposable gloves, papertowels and the Hoppes, you're looking at finish work smooth as a hound's tooth. Find Hoppes spray in most Camping aisles where gun supplies are featured. There are other brands too at WallMart. That's my truth and I'm stickin' to it. Hope this helps ya.
Ed
Wardinbb is offline   Reply With Quote
Old 09-08-2003, 12:13 PM   #4
Profile:
Images: 8
How to apply Vulkem?
Well, spent the weekend removing the gaskets around the doors and two little windows (same side). Now just have to get the gaskets back on.
question is - notice places that had Vulkem? and need to reseal between where the window and skin meet. I tried using a small syringe in the corners of the windows but guess I'm not doing it right.
Please someone tell me how to appy this stuff - with a syringe or your fingers??
stellablu
stellablu is offline   Reply With Quote
Old 09-08-2003, 01:24 PM   #5
mareinmn's Avatar
Profile:
ellablu
Please Say You haven't used that dredded V stuff yet.
Even the factory is using the GE Alumin. Silicon caulk that you can get from Home Depot Etc.
Much easier (small caulking gun), color matches, and stays pliable forever.
mareinmn
mareinmn is offline   Reply With Quote
Old 09-08-2003, 01:58 PM   #6
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
...maybe so with the newer trailers, however, Vulkem was the sealer used in the vintage trailers. From our experience, the two do not mix well. We had a PO that used silicone caulk over the old Vulkem and we had nothing but problems with it adhering. I believe it is better to stick with the original, rather than mixing the two, to save yourself a bunch of future problems.
We applied the Vulkem using a syringe and masking tape. There was a great thread posted a while back that's packed with info & "How To's" to help you out, here's a link:
Tell me more about caulking...
Shari
InsideOut is online now   Reply With Quote
Old 09-08-2003, 05:37 PM   #7
Profile:
All the Vulkem I ever have used came in a tube for a caulking gun. Is it available in some other form?
I have seen nothing about AS switching to aluminum silicone caulk. I understand they switched to Sikaflex some time back; I have used some and it seems to be an excellent product as well. The color blends a bit better with the aluminum than Vulkem.
Vulkem appears to remain pliable for decades. Maybe longer.
For really small seams I like Parbond.
Mark
Old 09-08-2003, 06:01 PM   #8
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
Mark,
The Vulcem is only sold in gun tube cartridges for the general public to buy.
Some members transfer some to a large volume syringe to have better control over the bead size when sealing smaller seams. I can understand this as the par bond seems to develop a hard cracked finish look as it ages. The Vulcem stays soft and finished the way it was when you left it.
Brett G
WBCCI #5501 AIR # 49
Old 09-08-2003, 06:41 PM   #9
Chas's Avatar
Profile:  Austin , Texas
Images: 22
Originally posted by mareinmn
ellablu
mareinmn
Really? What factory, maybe you can cue us in on where you got this bit of info.
Myself, I seriously doubt it. I remember a pic posted here somewhere that showed a case of Vulkem right on the production line. Yes, Vulkem can be messy but will hold up decades longer than any silicone, don't care what the tube says, 25 years, thirty years, all baloney!! I've peeled into some of the thirty year old Vulkem on mine and it is almost as fresh as the new stuff out of the tube, and stays stuck like nails.
Chas
Chas is offline   Reply With Quote
Old 09-08-2003, 09:01 PM   #10
Davydd's Avatar
Profile:  Tonka Bay
Images: 13
My take on Vulkem
Vulkem is a Tremco Company polyurethane sealant that is applied with a caulking gun. Someone mentioned Sikaflex, which is Sika's polyurethane sealant. There are several companies that produce polyurethane sealants.
Tremco lists about a half dozen different Vulkem products. They all come with a standard aluminum color amongst many other standard colors.
In looking at the different Vulkems it seems Vulkem 931 may be the best choice. It is a one-part non-sag sealant suitable for moving joints and vertical applications. It has a very fast drying time and good adhesion to aluminum. It's hardness is about average among the Vulkem products. Tremco also has Vulkem products suitable to be immersed continuously in water. This feature is the main selling point of the product.
One part Vulkem products come in tubes. There is also a two-part polyurethane Vulkem 222 but it comes typically in 5 gallon pails and must be mixed before use. I doubt no one but a sealant professional would want to tackle that and 5 gallons is way more than you would ever need.
Vulkems may have evolved over the years. It is hard telling what the older Airstreams actually had. I do know that polyurethanes have a useful life of about 10-15 years in building joint exteriors but we are talking about sealant joints that fill gaps from about 3/8" up to 2".
Silicone sealants have a theoretical longer life than polyurethanes. Typically 20 years. They are just as suitable in my mind. These kind of sealants didn't exist when vintage airstreams were being built.
Whether you use polyurethane (Vulkem) or silicone, you should thoroughly clean the joint down to bare aluminum.
Don't use acrylics, polyvinyls, or modified silicone acrylics--all typical stuff you can buy retail at Home Depot. To get the right stuff you may have to go to a commercial builders supply store.
That's my 2 cents today.
Davydd
Pleasure-Way Plateau Sprinter B Camper Van
2004 Nissan Titan LE Crew Cab
(Former vintage Airstream Owner)
http://www.tonkawoods.com
http://www.porktenderloinsandwich.com
Davydd is offline   Reply With Quote
Old 09-09-2003, 06:07 AM   #11
53flyingcloud's Avatar
Profile:  1984 29' Sovereign
Savannah , Missouri
Send a message via ICQ to 53flyingcloud Send a message via Yahoo to 53flyingcloud
Lightbulb Just abit of info
thenewkid64
So very true~!
This is the easiest way to control your flow..
The syringes can be bought from: Airstreamdreams
As best I can recall, the prices was well under a dollar per unit. The secret to controlling the flow is all in the cut. You should try to cut the tip of the syringe at a 45 degree angle and, make it as small or large as you need for the job.
Plus..keep this in mind, you can reuse the syringe numerous times with proper storage or cleaning, if you'd just clean it out after you're done.
Good luck~!
ciao
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 09-09-2003, 12:03 PM   #12
Profile:
Images: 8
Thanks all. I tried a little syringe I have from the baby's medicine and it still is a pain to do. Maybe someone can show me at a meet or something.
So - masking tape would be good, then do you make it flush with the skin by dragging a blade over it?
I think I need to contact a Chicago area person to show me how to do this before I ruin my trailer's skins!!!! Right now it doesn't really leak - except by two windows so it might hold till next year???
Stellablu
Old 11-01-2003, 07:51 PM   #13
TOM CRUMP's Avatar
Profile:  1970 27' Overlander
Braxton , Mississippi
Images: 26
Window Leak, Caulking Question?
Helping a friend with some fix-up on his '84 34' excella (in exchange for borrowing priviliges) The big stationary window left of door taking on water between panes, caulk on entire coach in bad shape, Questions: What is best tool for removing old caulk? Is there any way to get rid of the water? Is water getting in from some way other than bad caulk? Going with the Vulkem caulk, probably using acetone to get all residue. Yor replies are greatly appreciated, Tom
TC
TOM CRUMP is offline   Reply With Quote
Old 11-01-2003, 08:06 PM   #14
dscluchfc's Avatar
Profile:  1984 31' Excella
Abernathy , Texas
ParBond
My same window has fog in it too. I know you can take them out and reseal them, but I have not attempted it.
When I got my 84 Excella 31 ft, there was a number of leaks.... around the running lights, and tail light assemblies, and also where the ZipDee awnings were screwed into the skin.
I used ParBond aluminum caulk on all these spots. No more leaks. I used a metal awl type tool to remove the old dried up material which also appeared to be ParBond. Then reapplied ParBond. It flows very smoothly and nicely.
dscluchfc is offline   Reply With Quote
Sealants??? JAD Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 04-15-2004 09:33 AM
Floor cancer smily Repairing/Replacing Floor &/or Frame 15 10-13-2003 12:11 PM
