Old 12-21-2009, 12:57 PM   #239
Globie64's Avatar
1964 19' Globetrotter
The Sea Ranch , California
Images: 18
NOW I see the "silicone caulk remover". Thanks!
Wherever you go, there you are
Globie64 is offline   Reply With Quote
Old 02-20-2011, 06:59 PM   #240
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Old thread resurrected
I purchased these two sealants from Fastenal a few weeks back. Has anyone ever used the 3M 560 polyurethane adhesive sealant? It was a bit expensive at $15 per tube. The Tempro 626 is supposed to be like Vulkem 116 but has less work time. I have been using the Sikaflex 221. It has a nice finish to it. I don't dig the texture of vulkem.
Lance
Top is offline   Reply With Quote
Old 02-20-2011, 07:44 PM   #241
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Forgot the photo! Duh!
I purchased these two sealants from fastenal a few weeks back. Has anyone ever used the 3m 560 polyurethane adhesive sealant? It was a bit expensive at $15 per tube. The tempro 626 is supposed to be like vulkem 116 but has less work time. I have been using the sikaflex 221. It has a nice finish to it. I don't dig the texture of vulkem.
Lance
Old 02-20-2011, 08:01 PM   #242
soldiermedic's Avatar
Florissant , USA
I've used Sikaflex 221 and Trempro 626 both having good results. No clue about the 3M PU stuff though. I like the Sikaflex because it is really thick, and can be sanded down (I'm talking interior use for that).
Steve
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Old 03-18-2011, 09:22 PM   #243
Lotus72
Lotus72's Avatar
1970 27' Overlander
Eugene , Oregon
We have a '70 Overlander. We just pulled the musty carpets and found 2 layers of the bad boys. We also pulled the gaucho and table. Here are some pictures of the floor. Suggestions of what caused these leaks? Rivets are intact outside the leaks, the striping along the edge looks a bit worn, could be a source. Suggestions? '70 Overlander floor shot | Flickr - Photo Sharing!
Lotus72 is offline   Reply With Quote
Old 03-18-2011, 10:45 PM   #244
SilverGate's Avatar
2007 23' Safari SE
San Diego , California
Vulkem is now called TremPro
Originally Posted by Top View Post
... The tempro 626 is supposed to be like vulkem 116 but has less work time. I have been using the sikaflex 221. It has a nice finish to it. I don't dig the texture of vulkem.
Attachment 122699
Vulkem is now called TremPro.
I used TremPro 635 in white for caulking around the Fan-Tastic Fans on our Safari last fall. (TremPro 636 is available in aluminum color.)
I mentioned this in SilverGate's Safari is Home at Last! thread, post #484.
See details of this story in Fall Safari Prep, History Safari Express.
Name:	DSC_0024 Fan-Tastic Fan caulking.jpg
SilverGate is offline   Reply With Quote
Old 03-21-2011, 12:38 AM   #245
Stubborn but learning
filterman's Avatar
1973 31' Excella 500
washougal , Washington
Sikaflex 221 or Vulkem 116 What is the better sealant?
filterman is offline   Reply With Quote
Old 03-21-2011, 01:15 AM   #246
constructor's Avatar
1973 25' Tradewind
1960 28' Ambassador
New Smyrna Beach , Florida
Leaks Tops of Windows 73 Tradewind
Start at the top and work your way down. The vents (sewer and air) and AC were both leaking in our 73 Tradewind along with the windows. We havn't had a blowing rain since the constructor dug out the old vulkem and reapplied new. I think it is on page 1 of this thread were Andy describes sealing things. We have also installed all new window gaskets.
Ann - The Constructor's scribe TAC FL-20
Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover. - Mark Twain
constructor is offline   Reply With Quote
Old 03-21-2011, 08:03 AM   #247
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Having now applied both, I prefer Sika 221 because it is smooth. As far as how they stand up over time, I'm not sure yet. There is a good read on sealants under field notes on the VTS website.
Vulkem
Lance
Old 03-21-2011, 03:38 PM   #248
Sikoflex is smooth and dries fast. Do not use it when doing sheetmetal work
Vulkem is course and dries slow.
They both last a long...........................long time.
Old 03-22-2011, 12:19 AM   #249
filterman's Avatar
Sikaflex
Talked to sikaflex rep today he recommended to me 295 Marine Grade with activator because it wont chalk and has better uv stabilizers,sooooo at 11 bucks a tube I am using it on the stacked windows (only comes in black and white) I am using black and man is this stuff thick and nasty. Thanks Top,Constructor and of course Andy. I was reading that for the sheetmetal seams to use parabond but someone else mentioned another product Dymonic then theres dicor lap sealant?? Whats your take on the skins I am thinking Dymonic or Dicor. OHHHH Dont get any kind of alcohol on silka until it is cured completely or it will fail prematurely, straight from the rep. I had read where someone was wiping thier seams after applying sealant and using alcohol.
Bonding of Safety, Laminated, and Insulation Glass Windows
Old 03-22-2011, 11:34 PM   #250
filterman's Avatar
Marine grade 295 sika on stack window, I like the black.
http://www.airforums.com/forums/f261...tml#post967768
Old 03-23-2011, 04:57 AM   #251
lewster's Avatar
Naples, FL , Hood River, OR
I am a big fan of SikaFlex in all of the flavors. Works great in all recommended uses. I would not use Dicor lap seal though, as I have found that it tends to dry out after a couple of years of exposure to the elements and starts to exhibit shrinkage cracks, especially when used on roof sealing applications.
Old 03-23-2011, 05:19 AM   #252
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
I have always been partial to 3M products. I found this spec sheet on their website.
Looks like some good products to try.
Lance
caulk, caulking, sealant
Sealants??? JAD Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 04-15-2004 08:33 AM
Floor cancer smily Repairing/Replacing Floor &/or Frame 15 10-13-2003 11:11 AM
