Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Leaks - Weatherstrips, Gaskets, Caulks & Sealants
Old 07-16-2002, 03:30 PM   #1
Patriotic
Chuck's Avatar
Profile:  1973 23' Safari
Images: 99
Lightbulb Caulking and Sealants (silicone, parbond, vulkem & more)
perusing through the threads, I'm wondering: should I pro-actively seal all the seams on my "new" ('73) trailer, or just large gaps or known leaks? (there aren't any that I know of...yet, except perhaps a sloppy sillicon job around the front window). I'm reading that vulkem needs to be run in a rather thick bead....I can't imagine how that would look running up and down the trailer (yuck). Or is there some method for getting it into the seams, making it more or less invisible?
What is this "par-bond" stuff, and where do I get it?
what about the alluminum gutter/flashing caulk available at HD?
Chuck is online now   Reply With Quote
Old 07-16-2002, 06:28 PM   #2
airstreamcaravel's Avatar
Profile:
It "seems" to be a problem
Ditto! I have the same question. Anyone have some good proven techniques?
What is the best product?
airstreamcaravel is offline   Reply With Quote
Old 07-16-2002, 07:19 PM   #3
Commercial Vendor
Profile:  Corona , California
Vulkem is used for the large seams, such as at the top of the windows, entrance door, vent cover flanges and awning rail. It's also used to seal the vent pipe gaskets, through the fiberglass screening and on to the black vent pipes.
Parbond, comes in 5 ounce tubes and is used for small seams, such as segment seams and around the top and both sides of clearance lights, and around the sides of the window frames. It, like vulkem, never completely hardens. Very small beads can easily be made with Parbond.
We have used it for many years and keep much of it in inventory.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 07-16-2002, 08:03 PM   #4
PeterH-79MH's Avatar
Profile:
Images: 63
If you want your seams and windows look like this read on.
Once you figure out how to do it,
the instructions actually make sense.
_____________________________________
WBCCI Member at Large
PeterH-79MH is offline   Reply With Quote
Old 07-16-2002, 08:07 PM   #5
Profile:
Images: 63
get some 3M blue tape, 1" and 1 1/2".
On straight seams, place 2 strips leaving about 1/16" space, on corners place a piece of 1 1/2" tape and cut it with an Olfa type knife.
Old 07-16-2002, 08:16 PM   #6
Profile:
Images: 63
carefully remove the side on the skin and place it 1/16" from the frame for a perfect fit.
I personally like Tremco's (same co that makes vulkem) Dymonic Polyurethane Sealant. It sticks like thunder to aluminum and clearcoat and never dries hard. It is more liquid than vulkem and not so gritty. The color is a grey/aluminum. I bought it at the local glass company for $5.25 for a 11 oz tube. After forcing it into the seam using a caulk gun, I use a rag with paint thinner to smooth it out prior to removing the tape.
Old 03-19-2009, 10:01 PM   #7
zipman's Avatar
Profile:  1979 31' Sovereign
Tuscaloosa , Alabama
Where would you go to get this sealant? Also the vulkem, and parbond? Our '79 airstream has multiple leaks, I want to fix them all at one time.
Ken F
zipman is offline   Reply With Quote
Old 03-19-2009, 11:29 PM   #8
Profile:  1989 34' Limited
Mont St-Hilaire , Quebec
Vulkem 116 is the way to go for tour application..
Representatives/Distributors in Your Area - Tremco Commercial Sealants & Weatherproofing
HappyCampeur is offline   Reply With Quote
Old 03-23-2009, 04:36 PM   #9
Profile:  1973 27' Overlander
Space Coast , FL
Originally Posted by HappyCampeur View Post
Unfortunate: two of the companies listed in that link which are in my immediate area are incorrect. First one (in Rockledge FL) doesn't carry the product and suggested I call painting contractors. Second one (Palm Bay FL) has an incorrect phone number --- goes to a pretty interesting voice mail though .
I'll give Inland RV a shout. I need the stuff like yesterday.
funkill is offline   Reply With Quote
Old 03-20-2009, 02:11 AM   #10
Commercial Vendor
We have Vulkem and Par-bond.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 03-23-2009, 01:31 PM   #11
A Vulkem dealer AND a forum contributor, what else can you ask for more???? I love Andy already...
Old 03-20-2009, 08:20 AM   #12
silverleeper's Avatar
Profile:  1967 22' Safari
1960 18' "Footer"
Edmonds , Washington
Vintage Trailer Supply is also a good place to shop for sealant and other products.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 07-16-2002, 08:35 PM   #13
Profile:
I'm all caulked up! Oohh haaa yaa!
PeterH,
That technique rocks! The product sounds interesting, I'll give it a try.
RVAndy,
As always, may god bless and keep you in our circle.
Dave
Old 07-16-2002, 08:54 PM   #14
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
Thumbs up
I'll store this thread away for later...
Thanks Andy for the clarification on the different sealers...and thanks to PeterH for the technique tip! Love it!
Shari
Sealants??? JAD Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 04-15-2004 09:33 AM
Floor cancer smily Repairing/Replacing Floor &/or Frame 15 10-13-2003 12:11 PM
