Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Leaks - Weatherstrips, Gaskets, Caulks & Sealants
Old 02-21-2007, 12:51 AM   #155
Fyrzowt
Fyrzowt's Avatar
Profile:  2000 25' Safari
Templeton , California
Images: 8
Originally Posted by lewster
Dave,
I believe it's a pint and mine has been useable for over a year. You just have to clean out the applicator tip once in a while................
Ah, it's all about perspective and maybe camera zoom.
Thanks, good info in these posts. I'm going to be doing a lot of sealing this spring - Preventative maintenance.
Dave
Fyrzowt is offline   Reply With Quote
Old 02-21-2007, 06:25 AM   #156
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
Nothing Special....
Originally Posted by SilverGate
Fyrzowt… lewster is right… it is actually a can holding 16 fl. oz. of sealant.
The applicator came with no instructions, so after my application, I unscrewed the applicator and pumped the remaining sealant back into the can and flushed out the applicator with the recommended isopropyl alcohol.
Lewster… thanks for sharing your experience with Acryl-R… if I read you right, the next time I put the applicator in the can, I should just leave it in there until the can is used up… and occasionally use the wire pin that they supply to unclog the nozzle?
And do you store this can in a cool or cold place?
SilverGate
SG,
It rides around in my service van with nothing special done to it except tape on the nozzle......unlike the SikaFlex wcich goes off in 24 hours regardless of what you do to the tube unless you refrigerate the remainder immediately after use.
The pin thru the nozzle works fine to clear it.....seems like the product left in the gun stays fluid as it's just the stuff in the tip that needs cleaning. And that's probably due to the very small diameter there. GREAT STUFF!!
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 02-21-2007, 07:50 AM   #157
SilverCabin
SilverCabin's Avatar
Profile:  2007 23' Safari SE
Viera , Florida
Level Master Mounting
Originally Posted by BIGED52
Randy, Always.... Always put some sealer in new drill holes and dip the aluminum screws threads in sealer before installing them. You shold be fine with gutter seal as a temporary seal just keep in mind it will probably dryout and crack sooner than Vulkem or Sikaflex or Acryl-R. Where did you purchase your Level Master? Ed
Thanks Ed. I purchased the Level Master from Camping World; it was on sale for their club members. I liked it because I could see the level from the truck driver's seat, and it matched the Airstream in its aluminum bracket.
Randy
Randy and Pat Godfrey
2nd VP Florida Unit
WBCCI# 7591 - AIR# 17017
2007 Safari SE 23' - Daisy
2006 Lincoln Mark LT - Hoke
Read our Travel Blog at: www.silvercabin.net
A journey of a thousand miles, begins with a cash advance
SilverCabin is offline   Reply With Quote
Old 02-22-2007, 12:32 AM   #158
BIGED52
BIGED52's Avatar
Profile:  1967 22' Safari
MILAN , Illinois
Level Master
Thanks Randy, I'll check it out at Camping World and see about picking one up for my trailer as the ancient one on the tongue is rotted into three pieces. Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004
AIR#7110
"My tire was thumping, I thought it was flat!
When I looked at the tire... I noticed your CAT!"
Burma Shave
BIGED52 is offline   Reply With Quote
Old 02-22-2007, 12:39 AM   #159
SilverGate
SilverGate's Avatar
San Diego , California
Thanks, lewster, for your sharing your experience in storing Acryl-R...
And ability to keep applicator in can and still functioning over time is nice!
And thanks for the details to clancy boy on white-top surface prep before adding more sealant.
SilverGate
SilverGate is offline   Reply With Quote
Old 03-27-2007, 06:31 PM   #160
Crusty
Crusty's Avatar
Profile:  1992 34' Excella
Hey guys, new owner here but I have had considerable experience sealing up sailboats and I thought of a leak detection trick that I've used on boats which ought to work equally well on AS's.
Essentially, the technique is to seal the entire trailer up using duct tape around gaskets, etc so that the interior will hold a bit of a positive pressure. Some connection is then fashioned to plumb the exhaust from a shop vacuum into the interior. With the interior pressurized, you go over all the likely leaks from the outside with soapy water looking for bubbles.
You can find really small leaks on sailboats this way and I believe it might work on AS's too.
Crusty
"If you come to a fork in the road, take it."
Austin, TX "Rancho Deluxe" '92 Excella 1000 34'
Crusty is offline   Reply With Quote
Old 03-27-2007, 08:57 PM   #161
lewster
Commercial Vendor
lewster's Avatar
Hey Crusty,
Thanks for posting that technique. I have used it a lot in finding small leaks in a variety of RVs.
I'm sure others here will benefit from it, and karma to you!
AIR # 10325
Old 04-05-2007, 12:39 PM   #162
DPeakMD
DPeakMD's Avatar
Profile:  1975 23' Safari
1978 31' Excella 500
Franklin , Indiana
How to Assemble Acryl-R Caulk Gun
Got my shipment of Acryl-R, Vulkem and Parbond from Airstream today. There were no instructions with the applicator for the Acryl-R. Can anyone help out with how this goes together?
I see how the gun goes onto the can and how the nozzle attaches to the gun. What about the other springs and parts??? The box was already opened, so I want to make sure all the parts are there.
Dallas
WBCCI/VAC #8481
AIR #9
W9CDC
DPeakMD is offline   Reply With Quote
Old 04-05-2007, 07:37 PM   #163
lewster
Commercial Vendor
lewster's Avatar
I've never broken mine down that far, but I'll dig it out and see what goes where and post back in a day or 2 .
AIR # 10325
Old 07-04-2007, 11:02 PM   #164
REDNAX
Aluminum Vintage Kin
Profile:  Corpus Christi , Texas
Boys, I sure appreciate this thread. Taking the 34' 1983 Silver Streak to a shop tomorrow where we'll get the forklift up to remove/replace/repair all that penetrates the roof. Used VTS to have extra Parbond on hand, and will use one of the polyurethane sealants on the big stuff.
Looking forward to trying the 3M pinstripe remover wheel mentioned early in this thread.
Allow me to pass along what I've been using (among other tools) to remove silicone from this anodized skin: wandering through WEST MARINE one day I came across plastic razor blades (with holder) that work like a champ. Cheap, and each blade seems to last a few feet before needing to reverse or change.
I realize that adhesion may be quite different between the skin on yours versus mine, but these are slick.
REDNAX is offline   Reply With Quote
Old 07-09-2007, 05:39 PM   #165
Jacob D.
Jacob D.'s Avatar
Profile:  1964 26' Overlander
San Leandro , California
I've been replacing existing seals that had been gooped over with clear silicone (which had then split) with Alcoa Gutterseal, and thought I'd share a little bit of my limited experience...
Vulkem is great when you have two pieces you can squash it between. If you're trying to fix a seal on two pieces that are already joined, not so much. I've found the Gutterseal actually does wick into the seams as promised and tends to leave a very good and quite inconspicuous seal. I'm using it around the window frames and hatch openings on mine.
But one caveat - I tried masking off (with blue painter's tape) about 1/8" from the seam on the lower side and right along the edge on the top side, then applying the Gutterseal along it - and it goes on very nicely in a small bead from the tube, usually - but the masking is worse than a waste of time, it actually ruins the seal when you pull it up. Best just to try hard to do it "right" the first time and deal with cleaning up any untidiness when it's dry.
The problem is that the sealant sticks better to itself than to the metal. So if you hit the tape with the sealant, when you pull it off you'll pull the sealant away from the skin or out of the seam. Even trying to cut with a razor along the edge of the tape didn't help - the Gutterseal really wants to stay stuck to itself.
However, the sealant really does seem to go into the seam, and it also seems to level out quite a bit, so even something that looks a little untidy when you put it on will settle into something that looks nicer (so far as I can tell, anyway). So my suggestion is just to carefully apply down the seam without masking and try to clean up any excess once it dries.
Masking seems to work much better with Vulkem, which will tear more cleanly and won't pull out of the seam when you pull away the tape.
Anyway, just a couple of experiences. Maybe I'm doing something wrong, wouldn't be the first time...
Jacob D. is offline   Reply With Quote
Old 07-09-2007, 06:45 PM   #166
HiHoAgRV
Profile:  1977 29' Ambassador
Brandon , Mississippi
Images: 26
Before I start resealing, I have to remove this goop. Anyone know what it might be? It seems to have migrated away from where is was originally placed.
Hi Ho Silver RV!
Vernon, Sarah, Mac the Border Collie and-
'Epiphany' the 29' Airstream
Old 07-09-2007, 07:03 PM   #167
lewster
Commercial Vendor
lewster's Avatar
Don't know what it is....but try a hair dryer or low setting on a heat gun. Don't get the aluminum too hot and scrape off most of it with a smooth edge plastic scraper. Then remove the remaining residue with 3M adhesive remover.
Also try to get it out of the seams where possible to get a really solid bond with your new sealant (hopefully Vulkem or my preference: SikaFlex 221 in grey).
AIR # 10325
Old 07-09-2007, 07:37 PM   #168
wahoonc
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
Jacob,
If there is ANY silicone residue left it will affect the adhesion of any new sealant. I usually use something like gasket remover to make sure it is clean prior to using Vulkem, Sikaflex or Parbond. BTW the gasket remover WILL eat clear coat
Aaron
WBCCI #2449 AIR #2495
Sealants??? JAD Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 04-15-2004 09:33 AM
