02-10-2007, 01:27 PM
#141
Out in left field......
Possum Holler
, Georgia
I used Parbond behind seams and in other areas where it can't been seen. Primarily where the banana wrap attaches. You're right, it's messy. The Sikaflex is very hard to use also, it takes two hands to sqeeze it out of the tube, and then is goopy once out. Sticks to everything and is near impossible to get smooth. Thanks for the tip.
I love the smell of campfire in the morning
www.nesa.org
Air No. 6427
02-19-2007, 11:58 PM
#142
2007 23' Safari SE
San Diego
Acryl-R - Official Seam Sealer for Airstream Trailers
Lewster (post #127) and wahoonc (post #138) got it right…
Alan Wuebbenhorst, Airstream Relations Representative confirmed last week to me…
That Airstream uses Sikaflex 221 for large work and Acryl-R for the small stuff…
Such as sealing seams. Good, just what I needed for the missing sealant over my Vista Window.
It was my only leak allowing a few drops of water to trickle down onto the blinds next to Galley.
So I ordered Acryl-R with its wonderful applicator from Airstream’s Store:
http://www.airstream.com/shop/dynamic.php?ProdCat=Maintenance&action=cat&offset= 15
The product came Friday and I applied it last Saturday (See photos below).
Acryl-R is a small joint sealant designed for sealing mechanically fixed joints.
Information on the can continues, "This sealant has excellent resistance to ultraviolet radiation, atmospheric oxidation, and temperature extremes. It remains ductile and adheres to most commonly used fabrication surfaces."
I agree with lewster that application is easy and cleanup can be done with isopropyl alcohol.
I am happy to tell you that after heavy rains last night and today, I’ve not had a single drop of water enter trailer!
SilverGate
02-20-2007, 12:02 AM
#143
2007 23' Safari SE
San Diego
Areas of missing sealant over our top Curbside Vista View Window:
02-20-2007, 12:04 AM
#144
2007 23' Safari SE
San Diego
SilverGate applying sealant for his first time!
02-20-2007, 12:06 AM
#145
2007 23' Safari SE
San Diego
Application close-up:
02-20-2007, 12:58 AM
#146
_
hi silvergate...
excellent demo shots!
the acryl-r has 2 nice/unique characteristics...
1. it seeps into the gap via capillary action,
2. as it dries any high spots seem to retract/flatten
so even a beginners work can look great.
on the negative side, it doesn't last as long as 221 or vulkem...
so usually it isn't applied in critical seams or really high stress areas.
trim, tail lights, running lights, and alcoa panel overlaps are the usual places...
i had a gap along the top of a vista view, like your photo,
and the a/s factory guys used sikaflex there.
they applied a big glob sort of like doing home/bathroom sealant.
then mushed it into the gap and wiped 'some' of the excess away; then applied more.
so there was a big line of sealant. they LIKE using large amts of this stuff.
i asked the fellow "why not acryl-r there?" and
he said the window frames flex/contract differently than the panels with heat/cold ....
if your work doesn't survive the california sun, next time try the sikaflex.
but the acryl-r kit is fun to use...
cheers
2air'
02-20-2007, 01:48 AM
#147
2007 23' Safari SE
San Diego
Thanks, 2air’… Well I did get a tube of Sikafex 221 from our Airstream Dealer…
He told me the trick is to smooth it on with a moistened finger.
So if that Acryl-R does not hold where I put it, I’ll sic Sikaflex on it!
SilverGate
02-20-2007, 05:21 AM
#148
Marco Island, FL
, Hood River, OR
Watch those expiration dates.....
..............on the SikaFlex tubes. they seem to brcome virtually unuseable on or about the date printed on the label.
Lew Farber - RVIA Nationally Certified Master Tech.... MASTER TECH RV SYSTEMS, INC.
AM SOLAR SALES & INSTALLATIONS ..... MAGNUM INVERTERS.....LIFELINE BATTERIES
NO MORE AIRSTREAM.... NO MORE MEMBERSHIPS.... BUT I'M STILL AROUND!
02-20-2007, 06:02 AM
#149
St. Cloud
A partially used tube can be saved by putting aluminum foil over the snout, throw it in a couple bread wrappers and toss it in the freezer. Like camera film (do they still make that? ... and Airstreams?) the freezer can probably extend beyond an expiration date. Don't use my name in explaining it to any domestic partner!
Sikaflex is usable pretty quick out of the freezer. I probably would worry about sweating and adhesion if you use it cold in a humid environment.
02-20-2007, 12:44 PM
#150
2007 23' Safari SE
Viera
Mounting Level Master Level
I need to drill four holes in the front panel just under the window to mount a Level Master level. The Level Master is a large level in an aluminum frame. I've got aluminum sheet metal screws for the mounting. Do I need to put any sealer on the holes before and/or after I drive the screws? I have a small tube of aluminum gutter sealer (Seamer Mate, it was mentioned around post #70 in this thread), can I use that, so I don't have to buy a big tube of something that will go to waste?
Randy and Pat Godfrey
Newsletter Editor, Florida Unit
WBCCI# 7591 - AIR# 17017
2007 Safari SE 23' - Daisy
2006 Lincoln Mark LT - Hoke
Read our Travel Blog at: www.silvercabin.net
A journey of a thousand miles, begins with a cash advance
02-20-2007, 02:16 PM
#151
1967 22' Safari
MILAN
Level Master Level
Randy, Always.... Always put some sealer in new drill holes and dip the aluminum screws threads in sealer before installing them. You shold be fine with gutter seal as a temporary seal just keep in mind it will probably dryout and crack sooner than Vulkem or Sikaflex or Acryl-R. Where did you purchase your Level Master? Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004
AIR#7110
"My tire was thumping, I thought it was flat!
When I looked at the tire... I noticed your CAT!"
Burma Shave
02-20-2007, 03:54 PM
#152
2000 25' Safari
Templeton
Is that gallon can of Acryl-R pictured above going to dry out like the tubes? Will it need to be used right away?
Dave
02-20-2007, 07:09 PM
#153
Marco Island, FL
, Hood River, OR
Dave,
I believe it's a pint and mine has been useable for over a year. You just have to clean out the applicator tip once in a while................
02-20-2007, 07:27 PM
#154
2007 23' Safari SE
San Diego
Fyrzowt… lewster is right… it is actually a can holding 16 fl. oz. of sealant.
The applicator came with no instructions, so after my application, I unscrewed the applicator and pumped the remaining sealant back into the can and flushed out the applicator with the recommended isopropyl alcohol.
Lewster… thanks for sharing your experience with Acryl-R… if I read you right, the next time I put the applicator in the can, I should just leave it in there until the can is used up… and occasionally use the wire pin that they supply to unclog the nozzle?
And do you store this can in a cool or cold place?
SilverGate
| Thread Tools |
| Display Modes |
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Sealants???
JAD |
Leaks - Weatherstrips, Gaskets, Caulks & Sealants |
1 |
04-15-2004 08:33 AM |
Floor cancer
smily |
Repairing/Replacing Floor &/or Frame |
15 |
10-13-2003 11:11 AM |
