Old 02-07-2012, 04:15 PM   #15
1976 Argosy 26
Simsbury , Connecticut
Hey, how did someone fix my typo in the title? I'm new to posting and couldn't figure it out and was embarrassed!
Gary H is offline   Reply With Quote
Old 02-07-2012, 04:54 PM   #16
Lily&Me's Avatar
Normal , Illinois
Certainly a tad bit of moderator wizardry.
Ya gotta love the name of this stuff, really! Reminds me of the shirts that Duluth Trading Co. sells to cure plumber's butt!
Maggie
Old 02-07-2012, 05:22 PM   #17
1976 Argosy 26
So it looks like I have my first and foremost spring project, clean every rivet and seam around and above the leaks and apply this stuff and hope for the best. (Should I just apply it to every seam and rivet?) Also, keep a rag nearby to wipe up any drips. There's really only three spots of concern, on either side of the door entrance and under the curbside wrap around window in the front. I already applied Liquid Nails Polyurethane sealant to the obvious places which slowed them down a bit but did not stop them.
Gary.
Old 02-07-2012, 05:49 PM   #18
1976 Argosy 26
It also seems more leaks appeared once it got cold here in New England.
Old 02-08-2012, 05:28 PM   #19
Holts Summit , Missouri
This stuff sounds fantastic. I'm going to have to get some and give it a try. Thanks for the information.
Windwalker55 is offline   Reply With Quote
Old 11-27-2012, 01:18 PM   #20
1960 17' Pacer
Peterborough , Ontario
Creeping Crack Cure follow up?
Hi folks,
Anyone care to follow up with their experiences last year with Capt Tolley's? Pics, tips on clean up, etc?
Thanks!
AlumaBorg is offline   Reply With Quote
Old 12-03-2012, 06:35 PM   #21
Phoenix , Arizona
I second this question - is this still the recommended product??? Any new info on this?
Cheryl
girlscan2 is offline   Reply With Quote
Old 12-03-2012, 06:53 PM   #22
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Recommended....not sure.
This is still what I use for any narrow gap leak repair.
Name:	small_Acryl-R 16oz Can.jpg
ID:	173847   Click image for larger version
Old 12-03-2012, 07:32 PM   #23
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
I am still happy with it. None of the leaks sealed by the Capt. have started leaking again. I did, however, use it for the narrowest of leaks. If I could visually see the crack, I used the above Acrul-R.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 12-10-2012, 05:37 PM   #24
1960 17' Pacer
Thanks for the follow up!
Old 12-11-2012, 08:25 AM   #25
Phoenix , Arizona
Great! Thanks for the update.
Cheryl
Old 12-17-2012, 04:48 PM   #26
Phoenix , Arizona
Leak in the back
GRRR - I have a persisten leak in the back that I THOUGHT I had fixed but apparently not after taking a look today (from rain last weekend.) I thought it was the seam where the dent is showing in this picture. What else could it be??? Or is it probably still that area that I need to take the seatant out of and try again? Again I say GRRR!
Thanks for your advice (PS I know I have the cart before the horse here; wishful thinking
ID:	174834   Click image for larger version
Cheryl
Old 12-17-2012, 06:36 PM   #27
Thumbs up
I would....
Remove the belt molding, inspect, clean, repair as needed,(dent) and reseal.
Pay close attention to the belt rivets, panel seams, tail-lamp bezels, clearance lights.
FWIW...new style belt molding is available.
Old 12-18-2012, 07:25 AM   #28
Phoenix , Arizona
Thanks Bob! Is there a thread that tells how to remove and repair? The more I read the less I know.
http://www.airforums.com/forums/f456...ml#post1239338
Cheryl
How far do you pull in a day urnmor On The Road... 75 07-15-2013 09:47 PM
Drips - Dehumidifier info Needed hoofer Full-Timing 11 02-25-2012 12:58 AM
Plastic bathroom components crack repair with 3M 4240 semi-rigid plastic repair kit Top Upholstery, Blinds, Walls & Interior Finishes 1 05-09-2011 07:11 PM
Rear storage crack and separation of trim 2008 Classic 30' SilverBeast Exterior Storage Compartments & Access Doors 37 04-03-2011 11:22 PM
