Old 07-05-2016, 07:00 PM   #1
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
Captain Tolley
Just curious if Captain Tolely has an negative effect on other forms of caulking when used in conjunction.
For example, if you suspect a leak around a window that has been caulked and used CT after the caulking has cured, will it have an effect?
Old 07-05-2016, 08:51 PM   #2
dznf0g's Avatar
Oswego , Illinois
I have done just that. When an unexpected leak occurs on the road, where polyurethane has pulled away from the skin, for example. It works and I have gone months or more before getting around to replacing the poly with no further leaking. Long term, I don't know, but certainly works for a quick repair with no apparent incompatibility.
-Rich-
Old 07-05-2016, 09:14 PM   #3
Morgan guy's Avatar
2007 27' Classic FB
Fredericksburg , Texas
I Had rubber seals on a window that were cracking and letting moisture in. I used Captain Tolley to seal the cracks. I did have to multiple applications to completely seal it.
The Tex-i-can is Ready to Camp
Morgan guy is offline   Reply With Quote
Old 07-05-2016, 09:45 PM   #4
dznf0g's Avatar
Oswego , Illinois
Yes, and I have used it on the door window rubber to glass interface for a permanent fix, as water was getting inside the door and draining out on the aluminum sill.
-Rich-
Old 07-06-2016, 07:34 PM   #5
Hans627's Avatar
Thanks gentlemen. I'm going to give it a try.
Old 07-25-2016, 04:22 PM   #6
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
I used Captn tolley on joints around the windows, doors and around panoramic windows on the 2005 classic.
it appears when it dries it a clear strong material that looks to be inert for the most part. You should cut the tip real small..and clean the area you are you are going to reseal.
I just let it dribble while moving it along the cracked gaps stopping when i was really taking the juice. I flows nice around the curved frame of the glass sucking in along the way.
I plan to retreat the area again, after this heat breaks in NC, to make sure it a good seal.
highly recommend and keep a good supply of paper towels on hand to catch over fill..
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D
TUG2.net check it out for good rental deals
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
carl2591 is offline   Reply With Quote
Captain Tolley's Creeping Crack Cure Gary H Leaks - Weatherstrips, Gaskets, Caulks & Sealants 38 10-25-2013 08:13 PM
Turning Captain's Chair? swansome Sprinter and B-van Forum 5 01-17-2010 03:34 PM
Captain Paul paulb Member Introductions 22 11-19-2006 10:55 PM
owner, operator, captain richard morg Member Introductions 4 04-28-2006 05:32 AM
Captain Morgan cptmorgan Member Introductions 4 04-10-2006 06:32 PM
