Old 12-21-2015, 03:36 PM   #1
2001 30' Excella
Full-time traveling , Hmmmm. what day of the week is it?
Can't get rotted screen door seal off
Any help or suggestions will be welcome.
The rubber from the screen door has come off in places and is sticking to the door frame. (see 3 photos attached)
I tried Denatured Alcohol on the door frame and it does not even touch it to remove it. I mean it doesn't even soften it or anything. I actually think it likes it!
I tried a steel chisel, but all I get is scratches, which I do not want, so I stopped after a test try.
Does anyone know of a chemical or method that will soften the rubber on the door frame so I can take it off?
Thanks!
ID:	254273   Click image for larger version
2001 Excella 30' (Beauty)
2014 Ram 2500 Diesel 4x4 (The Beast)
http://www.LivingInBeauty.net
JBBeaubeaux is offline   Reply With Quote
Old 12-21-2015, 03:38 PM   #2
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Try carb cleaner. We used that to remove old gasket material from windows, and old vulkum.
Chris
Old 12-21-2015, 03:54 PM   #3
87MH's Avatar
1978 31' Sovereign
Images: 292
3M general adhesive cleaner #08984.
It's expensive, but worth it.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 12-24-2015, 11:37 AM   #4
2001 30' Excella
Carb cleaner worked!
I tried Carb cleaner because I am in the middle of the desert and could only find an auto parts store.
Carb cleaner worked instantly!
It is almost amazing how fast it softens the rubber.
First swipe/rub removes the black rubber, then a 2nd and 3rd time removes the remaining sticky adhesive.
Thanks for all the advice.
Old 12-25-2015, 12:29 PM   #5
Jim,
The simplist and very best way to remove the door, screen door, access door and window gaskets, is first with a putty knife. Remove what you can. "THEN", place a small wire wheel into a drill. Burnish off the rest of the gasket that remains.
Why is this better than any chemicals ??
Because you not only remove the old gasket and adhesives, you "burnish" the metal, which in turn, provides a much more positive surface for the new gasket and adhesive or tape as the case may be.. Plus, there is no liquid waste to bother you.
Try it, you will love it.
Old 12-25-2015, 12:30 PM   #6
WBCCI # 23456
2000 30' Excella
Greeneville , Tennessee
Try lacquer thinner. Just don't breathe the fumes.
jimfa440 is offline   Reply With Quote
Old 12-25-2015, 01:46 PM   #7
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Also... Use a plastic scraper to minimize scratches and "tape" around sensitive areas... Just in case of slip...
I have used dry wood wedges or sticks... Someone even recommends "dried pig feet" you can get at a Pet store...
Peace and Blessings..
Channing
WBCCI# 30676
Old 12-25-2015, 01:55 PM   #8
Jeff I
2007 25' Safari FB SE
1964 22' Safari
Hammondsport , New York
Try heat
Try a hair dryer or heat gun and scraper. The heat should soften the old adhesive so you can scrape most of it off, then finish with mineral spirits or acetone.
J Ingersoll is offline   Reply With Quote
Old 12-25-2015, 02:06 PM   #9
2016 23' Flying Cloud
Charleston , South Carolina
Removing weatherstripping.
Acetone works well to remove weatherstripping.
73 de W4EOU?
blowingrock is offline   Reply With Quote
Old 12-25-2015, 08:05 PM   #10
1977 31' Sovereign
Lynnwood , Washington
Use lacquer thinner and a small wire brush (toothbrush size).
Tom
TomKirk is offline   Reply With Quote
Old 12-26-2015, 02:08 PM   #11
harryk's Avatar
1993 25' Excella
Venice , Florida
Scraped mine off like in your 2nd picture & then used a wire wheel in a small grinder to finish the removal & refinish the metal/aluminum where the gasket was. It looks it was made that way now. I have not put any foam back on it....2 years now & I do not think I will.
harryk is offline   Reply With Quote
Old 12-26-2015, 02:40 PM   #12
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I used Goof Off and a light application of a sharp paint scraper on my screen door seal. Apply the Goof Off and let it work for a couple of hours. Using the paint scraper and a green pad to remove all residue. You might have to go through the procedure a couple of times to remove all the glue. Then use rubbing alcohol to throughly clean the area and apply the correct soft foam tape as supplied by Vintagetrailersupply. Patience is key to a nice clean surface.
MICHAEL
Old 12-26-2015, 03:48 PM   #13
2001 30' Excella
Success!
Attached are a few photos of the successful process.
The carb cleaner really did the job and the doorway looks almost brand new.
Again, thanks for everyone's advice.
I now need to order a new screen door seal.
ID:	254658   Click image for larger version
ID:	254660   Click image for larger version
Rotted floor between door and sink corner Knudsvig Repairing/Replacing Floor &/or Frame 17 05-01-2015 12:44 PM
2 X 4 floor supports rotted off at rear Sprouty All Argosy Trailers 8 03-13-2014 05:06 AM
Is there a gasket/seal for a screen door? seismicfish Doors & Locks 8 03-12-2014 08:55 AM
Need screen door seal 63air Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 05-15-2009 09:52 AM
Weather seal for '57 door and screen door cdmagda Doors & Locks 0 09-01-2005 09:40 AM
