Old 02-22-2009, 10:19 AM   #1
1978 23' Safari
fair oaks , California
butyl putty tape on the roof
I am re-sealing the roof vents on my 78 safari. The current seals appear to be 2 inch wide flexible material the run the entire perimiter of the vents.
I found butyl putty tape thats seem to be a good candidate for a replacement material. Most usage directions indicate that this is used when installing the vents. After celaning off the old material , I want to "coat" the entire perimeter rivets with it.
does anyone have any experience using this on a roof? Since the material is fully exposed, how does it hold up to the heat? Will it remain sicky and
collect debris?
Bill
bacevedo is offline   Reply With Quote
Old 02-22-2009, 10:36 AM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Is the what we are talking about...Butyl Rubber Tape - Flexible tacky adhesive Sealing Tape
If so, it does remain sticky until enough stuff is stuck to it. I would wonder how UV resistant it is.
I have used PL Polyurethane for a sewer vent repair, has worked very well, stayed ply-able. On it's third season now.
Ck your black tank vent while your up there, if fact ck 'em all.
Name:	SOLAR PANELS; ROOF LEAK 021.jpg
PFC
"Tahawus"
RLC
Step aside Starbucks, this is a job for alcohol.
Old 02-22-2009, 11:19 AM   #3
1978 23' Safari
yes, that the stuff...specifically Putty Tape - Flexible Grey Rope Tape Sealant
I just like the idea of just taping the seams. I'll look into the roof flashing sealant
Old 02-22-2009, 12:02 PM   #4
collect debris?
Bill
Putty tape, "does not" hold up in the sun, period.
Reseal all roof openings with Vulkem. That will do just fine, for 40 years or so.
Old 02-22-2009, 03:45 PM   #5
Cyclist
henw's Avatar
2007 28' International CCD
Windermere , Florida
Try C 10 Flow Seal. Self leveling caulk that is incredibly easy to brush or flow on.
Dyco C-10 Flow Seal Caulk, Self Leveling, Extremely Weather Resistant
Tom
2007 28' Int CCD.
2011 F 250 Big Honking Diesel
DTV 5lnb on a tripod.
Wilson wired repeater with YAG.
Two big screens
15dB Backfire WiFi antenna and WaveMagnum
Centramatics.
Hawkshead Tire Monitors.
henw is offline   Reply With Quote
Old 02-22-2009, 05:09 PM   #6
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Butyl sealants whether tape or tube based are intended to be used in joints where they are in compression and away from UV exposure. For exposed items like rivet heads and around the edges of vents you want Vulkem, Sikaflex or the current factory favorite Acryl R.
Aaron
WBCCI #XXXX AIR #2495
Roof repair advice - hole in roof 1956 vintage casaalumina Roof 5 10-05-2008 10:24 PM
Source for pre-shimmed butyl tape pnb77 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 04-09-2008 09:48 AM
Seeking advice on replacing butyl tape sealant on ridged aluminum SOB SilvrSausage Vintage Kin 0 09-22-2007 11:03 PM
Plumbers Putty Buttercup Leaks - Weatherstrips, Gaskets, Caulks & Sealants 6 08-10-2005 02:28 PM
Cleaning debris from roof? White roof? maxandgeorgia Cleaning, Stripping & Polishing 1 06-05-2004 09:59 PM
