Old 02-28-2009, 07:30 PM   #1
moab , Utah
BolesAero roof seal
OK,I know this an Airstream forum but you guys are a wealth of helpful information.
I have a 65'Boles with a flat roof that sometimes turns into a pond. Before I replace all the water damaged ceiling(It's wood paneling,not aluminum),I need to seal the roof. The roof is sheets of aluminum with rivets and seams that have some sort of crimp together joint with no rivets. The seams and rivets have a hard as nails factory sealant that's deteriorating. Does any one know what they used back then and suggest what I can use? The whole roof was not sealed just the rivets and seams. Th roof also flexes a lot with movement and temp. changes.
Thanks for letting an aluminum kin in here.
ED
eddiemoab is offline   Reply With Quote
Old 02-28-2009, 10:22 PM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
its going to be a job
Hi,
Get the old caked sealer off the best you can. Many ways from wood or plastic scrapers to aircraft paint stripper in small amounts. MEK will work but wear gloves and avoid fumes. Alcoa aluminum gutter seal and Vulkem to seal it. Enjoy the ride.
Old 03-01-2009, 08:54 AM   #3
soldiermedic's Avatar
Florissant , USA
Pictures really would help in all this, but Robin is right for the most part.
Steve
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Roof repair advice - hole in roof 1956 vintage casaalumina Roof 5 10-05-2008 10:24 PM
Kool Seal or Vulkem for roof JimGolden Leaks - Weatherstrips, Gaskets, Caulks & Sealants 7 09-04-2008 03:58 PM
Vertical lip seal and trim seal for Classic Motorhomes rdm General Motorhome Topics 16 05-22-2006 07:49 PM
Roof seal 53flyingcloud Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 06-17-2002 03:32 PM
