Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Leaks - Weatherstrips, Gaskets, Caulks & Sealants
Old 10-15-2004, 10:47 PM   #1
Profile:
Question black sticky gasket?
My Alclad skin has arrived from AirParts. I've cut it to length. I've drilled and removed most of the rivets from the damaged area. There is what appears to be a black sticky gasket with fiber in it. Where can I get some of this gasket at?
crgintx is offline   Reply With Quote
Old 10-16-2004, 06:58 AM   #2
Profile:  , Minnesota
Images: 59
Airstream Registry
Try this place: http://www.austinhardware.com/produc...478&pf_id=3250 (They're in Dallas, not Austin)
Or do a search on 'butyl tape'.
Old 10-16-2004, 08:43 AM   #3
andoboba's Avatar
Profile:
Thumbs up Sticky black outdoor carpet tape
This sounds like carpet tape which is designed to be used outdoors. It is 100% weather proof! The tape looks like an impregnated black strip of fiber mesh. Good luck getting it off of anything. All big hardware stores should have it. I just used a bunch to apply R-4 aluminum sheet insulation to beef up and hold in the original fiberglass. Great stuff!! The tape sticks to dirty aluminum GREAT!
1969 29' Ambassador International
1994 K20 Suburban w/7.4l
1966 K25 Fullsize Truck w/5.7l
andoboba is offline   Reply With Quote
Old 10-16-2004, 06:50 PM   #4
Profile:
Talking Much thanks
I'll have to see if there's a dealer in Houston who stocks it.
Old 10-17-2004, 05:41 PM   #5
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
Somewhere , Over the Rainbow
I have used this stuff when repairing automotive A/C units. You can try an auto a/c parts supply store, if you can't find it anywhere else.
(No Longer at Inland RV)
Black & Grey valve trouble camphost Waste Systems, Tanks & Totes 51 08-18-2006 08:45 AM
Side window Glaze gasket Bfrank General Motorhome Topics 1 07-23-2004 09:04 AM
Sticky Black Water Valve squeeky Waste Systems, Tanks & Totes 3 04-09-2004 10:47 AM
Black tank flush.... drboyd Waste Systems, Tanks & Totes 11 08-01-2003 07:40 AM
Dual Gray Water & Dual Black Water? nvestysly Waste Systems, Tanks & Totes 5 05-09-2003 05:40 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
