Old 08-02-2014, 09:34 AM   #1
2008 23' Safari FB SE
Boulder , Colorado
Best sealant for exterior stove vent?
We want to redo the sealant around our exterior stove vent on an 08 airstream. I see that parbond comes in an aluminum color but I want to use a product that will remain somewhat elastic when cured so vibration doesn't cause it to crack.
What product is best for this sort of thing and what do you use to clean it up so the new seal doesn't show?
Thanks.
bonginator is offline   Reply With Quote
Old 08-02-2014, 10:15 AM   #2
lewster's Avatar
Naples, FL , Hood River, OR
Thanks.
SikaFlex 221 in grey. Perfect match for your aluminum. Great stuff too!
Old 08-04-2014, 04:51 PM   #3
Wishing's Avatar
2014 27' FB International
Clovis , New Mexico
Is this okay to use outside (on top of window)?...if so, can it be purchased?
Wishing is offline   Reply With Quote
Old 08-04-2014, 09:30 PM   #4
lewster's Avatar
It's the same sealant that the Airstream factory uses. Some Fastenal stores carry it. It is also available on line. Just Google 'Sikaflex 221'
Old 08-04-2014, 09:52 PM   #5
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Amazon and West Marine both have Sikaflex 221.
MICHAEL
Old 08-04-2014, 10:15 PM   #6
2008 25' Safari FB SE
Frederick , Maryland
I see it at Inland RV. I had trouble finding it in grey locally.
VWill is offline   Reply With Quote
Old 08-04-2014, 11:55 PM   #7
Wishing's Avatar
Clovis , New Mexico
Thank you for the good information-definitely going to make sure I have some before the next trip!
is this a vent? I ordered a Stove Vent from Inland and it was not what I needed Martha Roof Vents, Skylights & Fans 5 07-24-2014 05:35 PM
What sealant to use on exterior of Argosy? crabbey1 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 07-30-2013 03:12 PM
Exterior as factory sealant Mrad7777 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 02-18-2012 11:04 AM
Best sealant for exterior window channels? acltaos Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 05-26-2009 02:46 PM
Sealant Products - Exterior & Interior Cat Leaks - Weatherstrips, Gaskets, Caulks & Sealants 21 02-12-2003 11:00 PM
