Old 04-29-2007, 11:00 AM   #1
Ifihadtime's Avatar
1981 27' Excella II
Lynnwood , Washington
Question Belly pan / Side skin seam?
I guess you call the beauty strip where the belly pan and the side skin meet is the belt line. Anyway I was out hunting a leak today and when I hit the belt line with the hose water came into the belly pan. Itís a pretty big leak. I found it strange that the belly pan was put on over the outside of the skin which allows the water to flow right on in if there is no seal, itís like putting roof shingles on backwards.
? is this the way it is supposed to be and if so is it supposed to be sealed?
Itís hard to tell if this is what got the floor, I would think the water enters between the channel and the skin and misses the plywood.
Ron
81 Excella II
I am always doing that which I can not do, in order that I may learn how to do it.
Ifihadtime is offline   Reply With Quote
Old 04-29-2007, 11:41 AM   #2
Janets Husband's Avatar
1977 Argosy Minuet 6.0 Metre
1964 26' Overlander
1977 25' Tradewind
Eastern , Washington
I just pulled The belt line two minutes ago. I looked in the service manual and that is the correct layup. You are only supposed to "seal the top of the belt line molding only" I don't think this sheet metal layup caused your floor rot the lower panels come down about 1 1/2" below the level of the floor, it should be protected. Remember to seal the top of the belt-line though. I would also seal the pop rivets also, at least that is what I'll be doing.
Peace
Gary
Janets Husband is offline   Reply With Quote
Old 04-29-2007, 11:54 AM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
YMMV...my manual from 1975 shows it shingled under the side skins, however my trailer was built the other way around. I put mine back on with a bead of sealant just above the rivet line and a light bead at the top of the trim. All of my floor leaks were traced to windows, vent stacks and awning rails. The side sheets cover the edge of the flooring so I think that is a minimal point of entry for the water.
Aaron
WBCCI #XXXX AIR #2495
Old 04-29-2007, 12:48 PM   #4
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
I didn't use sealant on the molding, my thought was to let it run thru and out the bottom, I por-15'd the bottom edge of the banana skin and the edges of the belly pan also.
'77 Sovereign Intl 31' CB
Old 04-29-2007, 01:26 PM   #5
CanoeStream's Avatar
St. Cloud , Minnesota
A little terminology if you ever have to order vinyl inserts, etc. Beltline is the trim strip about chest high between the top and bottom halves. Rubrail is the lower trim strip at the junction of the belly & banana wrap and the trailer sides.
Yes, Airstream built a lot of trailers with the upside down lap. My '74 Argosy had a double-sided foam tape used as a sealer. You should apply a bead of Sikaflex 221 or Vulkem along there to seal it up when you put things back together. Definitely seal the rivets as Aaron says. On my Argosy the edge of the plywood floor extended a bit below the side aluminum sheet in a couple places, so would have gotten wet if I left it to drain freely.
5 meter Langford Nahanni
Old 04-29-2007, 03:20 PM   #6
Happycampers's Avatar
1979 30' Argosy
Havelock , where we park it
Ron, My 75 Argosy was the same way, as Bob said his was. And my 79 is the same way too. I am going to change that this summer on mine. The only thing I can figure is that was the last thing the factory put on before putting the rub rail on for ease of putting it together, the same thing you see in the auto industury.
Marvin & Annie
Niki (fur baby)
1979 Argosy 30 (Costalotta)
WBCCI 10103
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Old 04-29-2007, 03:58 PM   #7
1976 25' Caravanner
Campton , New Hampshire
You will often find it done both ways , even on the same unit , don't assume it's all the same if you check one area. Guess it was free choice at the factory .
ticki2 is offline   Reply With Quote
Old 04-29-2007, 04:16 PM   #8
Ifihadtime's Avatar
1981 27' Excella II
Thumbs up Thanks for the input
Thanks for all the replies, sure helps to have this resource to clear up one's confussion.It kind of looked factory, I think I will bead the seam before I put the rub rail back on. I would think the trim piece and skin would move around quite a bit under normal travel/ heating and cooling etc and it would be hard to maintain much integrity with only a seal on the rub rail.
I did figure it wasn't the source of my floor problem I think I'm going to clean and reseal all the windows, awning etc seams and call it good.
On another note mine has what looks to be a dual LED? light facing forward just above the belt line. I assume a guide for backing up in the dark. I pulled the cover off and there was about a 3/4" hole thru the skin to run the wires. Totally exposed other than a warped plastic cover. It might be my leak so I'll be fixing that, if yours has one you might want to take a look.
Ron
81 Excella II
Old 04-29-2007, 04:31 PM   #9
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
I am in the process of replacing all the lower skins on my Globetrotter. I removed the remainder of the banana wrap yesterday. All of my banana wrap was on the outside of the side skins and all the insulation was soaking wet from recent rainstorms. All the pieces that I have reinstalled are now underneath the side skins. IMHO this is the best way.
Old 04-29-2007, 05:02 PM   #10
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
Actually that was state of the art fiber optics. There was a FO cable that ran back to the turn lights so you could tell if they were working on not. I have it on my '80 Excella, but don't know if the cable is still intact or not.
Aaron
Removing Belly Pan garp Belly Pans & Banana Wraps 5 07-06-2016 12:48 PM
Installation of the new belly skin, pitfalls? etc. SaabLover Belly Pans & Banana Wraps 13 01-14-2007 08:58 AM
Need HELP! Need help quick - dropping the belly pan escapeez Belly Pans & Banana Wraps 8 12-30-2002 06:03 PM
Under Belly Skin Restoration... Andy R Cleaning, Stripping & Polishing 2 04-08-2002 11:46 AM
Re-attaching cabinets to the interior skin. Andy R Cabinets, Counter Tops & Furnishings 5 04-07-2002 02:54 PM
