Old 07-28-2015, 07:25 AM   #1
1977 31' Excella 500
Bonnyville , Alberta
Exclamation Battery Doors- Help
Hi Guys,
Stripped down to the floor and found significant water damage in the front. Looks to me that the source is the holes at the bottom of the access doors. Is there a gasket or piece missing on these? Both show daylight. See attached photos.
Thanks Guys!
Zenstream1 is offline   Reply With Quote
Old 07-28-2015, 07:34 AM   #2
Sorry I cannot upload the photos for some reason. But I am talking about the 2 holes beneath each door that allow cables to pass through I'm guessing??
Old 08-01-2015, 09:36 PM   #3
Name:	ImageUploadedByAirstream Forums1438486520.237503.jpg
Name:	ImageUploadedByAirstream Forums1438486570.816479.jpg
Old 08-01-2015, 11:21 PM   #4
astrocaver
1986 25' Sovereign
Denver , Colorado
What you are missing is the whole battery box. Regular batteries must be vented to the outside not the inside of the trailer. There is a plastic box that mounts to the battery door. The holes in the door are for ventilation and drainage. The battery wires pass thru gromets in the box that seal the unit. This compatment is sealed from the inside of the trailer. I just put a second one in my Sovereign. The missing box will let tons of water into the trailer and the floor will be ruined.
astrocaver is offline   Reply With Quote
Old 08-01-2015, 11:32 PM   #5
A W Warn's Avatar
2000 25' Safari
Davidson County , NC Highlands County, FL
Similar to this is what you need
Plastic Battery Box 1982 to Present 200855 [200855] - $29.95 : Out-of-Doors Mart!, More Airstream Parts on-line than anyone!
Alan
Old 08-02-2015, 02:32 AM   #6
airdreamers's Avatar
2008 27' International FB
Venice , Florida
Images: 14
I did the same as astrocaver, 2nd battery box. Zestream1, you are definitely missing thr inner battery box, as stated by astrocaver. A. W. Warn is giving you a great source for the box, and a great price also.
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 08-02-2015, 09:55 AM   #7
A W Warn's Avatar
2000 25' Safari
Those vent/drain openings are also a good place for critters to get in. I used a piece of fiberglass furnace filter to block the openings to mice, lizards, and bugs. That still allows ventilation and water flow.
Alan
Old 08-07-2015, 06:30 PM   #8
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
Note that there are two different battery boxes, depending on the year of your coach. You want the "77-81" box for your 77.
Check around on price plus shipping for your best deal.
Here's some cool detail on replacing the box.
Note that you must use either stainless steel screws or aluminum Olympic rivets, or we will all talk smack about you.
Why did Airstream change from front hinge doors to suicide hinge doors? arcamedies Airstream History 28 08-15-2019 12:06 AM
Sealing battery boxes and doors Eugiepayset Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 06-21-2011 06:39 PM
Adding battery compartments and doors Jammer Batteries, Univolts, Converters & Inverters 3 12-02-2010 03:48 PM
Battery compartment doors nwclassic Our Community 5 10-03-2004 08:28 PM
Doors for Battery and Stowage Compartment Joe Davis Exterior Storage Compartments & Access Doors 4 03-07-2003 06:27 AM
