Old 04-02-2012, 09:08 AM   #1
Wise Elder
Jammer's Avatar
2010 30' Classic
Basic questions on applying Parbond and Vulkem
Well, they don't stay new forever, and besides, I now have a 40 year old Cayo in addition to the 2010 Airstream. I've followed the caulking and sealing threads with detached interest until now, and now I need some advice.
I have a supply of Vulkem and Parbond laid in.
I believe my Cayo has quite a number of leaks. Like the former owner, I'm keeping it inside, so they haven't resulted in floor rot etc. I want to seal any sources of leaks before they result in water everywhere inside.
Questions:
1) What is the best way to remove old sealant and prepare the surface? Scraper? Wire brush? Chemical removers?
2) To what extent is it possible to reseal components without removing them? See, for example, the water inlet (photo).
3) What is the best strategy for determining what needs to be resealed? Just seal everything in sight? Garden hose? Sealtech air pressure machine? A combination?
Old 04-02-2012, 09:12 AM   #2
dznf0g's Avatar
Oswego , Illinois
I use a variety of PLASTIC scrapers, some with points and angles. Get them at HD. When there is a little residue left, I use Brakeclean. Doesn't damage clear coat or aluminum and gets it of really well. Some places require a razor knife to VERY CAREFULLY loosen edges of sealers.
Tape off and apply sealer, smooth out with fingertip and remove tape immediately....especially with Parrbond....it skins really fast.
I just tape off around components, unless there is a compelling reason to remove them.
With the age of your Cayo, I would systematically reseal everything, beginning with those areas which are showing cracking or pealing of sealer. On your AS, I would just follow around the unit and reaseal just those areas that show cracking and pealing, and stay on top of it so you won't ever have to do the whole thing at once.
-Rich-
Old 04-02-2012, 09:14 AM   #3
Wise Elder
Jammer's Avatar
2010 30' Classic
Thanks dzn. Makes sense.
My water inlet picture keeps showing up as a guitar. Forum software must be playing a belated April fool's joke on me.
Old 04-02-2012, 09:20 AM   #4
dznf0g's Avatar
Oswego , Illinois
Around components like the water inlet, trim with razor knife, tape off for a very thin bead of Parrbond. Others might say differently, but I really like the clean look of silver parrbond around items with small gaps.
-Rich-
Old 04-02-2012, 09:46 AM   #5
Tool Hoarder
West , California
With you on the Parbond. It looks great near water fills, trim etc. I like silkaflex on larger gaps. It flows out really smooth. I keep a squeeze bottle of solvent and go thru a lot of paper towels. I have also heard WD40 works well as a remover. I have yet to try it, probablly will this afternoon.
marzboy is offline   Reply With Quote
Old 04-02-2012, 02:58 PM   #6
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
No AF joke...a lot of pic's on the site changed over to a rusty hitch photo early this morning. Went to my Dexter thread and all the photo's were of a rusty tongue...very cornfusing at 6am.
Mod's must have got it straight all look normal now.
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
"Just because you don't know how, doesn't mean you canít."
Amanamus
"Never tow faster than your Guardian Angel can Fly"
Sweet Streams....🌥
Old 04-02-2012, 07:47 PM   #7
moparjohn's Avatar
1973 25' Tradewind
Ringoes , New Jersey
Parabond or vulkum
OK, So I'm trying to get my Tradewind more weather proof. I am removing and resealing some items (IE vent pipes, stove vent, roof vents, and I wamt to seal the seams on the aluminum skins. Which sealant for what job, and a quick why? Also, is there a reason my stove vent cover is screwed on not riveted? same with fridge? MPJ
moparjohn is offline   Reply With Quote
Old 04-02-2012, 08:01 PM   #8
Thumbs up
John,
Here's a thread that should help.
Acryl-R for the narrow gap panel seams.
Molly Ivins
Amanamus
Sweet Streams....🌥
Old 09-15-2018, 08:22 PM   #9
FIREHOSS16
1982 31' Limited
1977 31' Sovereign
1984 27' Sovereign
BELLVILLE , Texas
I want to seal the bottom band, I suppose that is the description, on an 82 Unlimited, any recommendations
FIREHOSS16 is offline   Reply With Quote
Advice on repainting an Argosy jimin pa Clearcoat, Exterior Paint & Trim 13 08-03-2013 08:21 AM
Mid way through interior vinyl removal - how to remove remnants and cross-hatch? mikeandnora Upholstery, Blinds, Walls & Interior Finishes 24 07-12-2012 10:12 PM
TX Veteran Designation on Drivers License Bluto Off Topic Forum 43 06-27-2012 01:31 AM
Suggestions for South Carolina RV parks on beach? Lothlorian Airstream Lifestyle 25 04-14-2012 08:36 AM
Dometic 360 not working on gas mode. AWCHIEF Refrigerators 5 04-02-2012 06:05 AM
