Old 03-11-2010, 02:49 PM   #1
slj
1973 31' Sovereign
northern , Minnesota
Awning holes
I was looking at possibly buying an Airstream that at one time had an awning. None of the hardware was there and the roof holes were not sealed. I have just started my Airstream search and need some advice. Thanks.
slj is offline   Reply With Quote
Old 03-11-2010, 03:14 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you can get to the outer edge of the floor directly under the holes poke the floor with an ice pick. If the floor is solid changes are it never took enough water to rot the floor.
Poke around the sill of the door and around the base of the toilet as they are other points of frequent rot.
Just take a good sniff for mold.
2004 Excursion 4x4
Old 03-11-2010, 03:18 PM   #3
Please keep in mind that there are and have been a bunch of awning manufacturers, some of which are history.
Looking for the awning holes could quite well mislead you.
The most popular awning for Airstreams is the "Zip Dee".
Visit their web site and you can see how their arms are mounted on the shell.
Awnings By ZipDee
You might get lucky and find an older Airstream with the old Zip Dee mounting holes.
Welcome to Airstreaming, and all it's questions.
Awning Rail Seal? & Awning Wardinbb Awnings 3 08-06-2013 02:37 PM
Replacing awning rod and fabric of original awning ? Mrcrowley Awnings 6 07-10-2012 06:42 PM
New toilet holes don't match old holes RichHog Sinks, Showers & Toilets 8 03-15-2009 06:36 PM
What are the holes for?? Silverfly 1960 - 1964 Overlander 6 09-01-2004 07:09 PM
Is the roadside awning option for a 28' Classic really just a single 19' awning? Dave Jenkins Our Community 1 08-17-2003 03:07 PM
