Old 03-06-2011, 05:17 PM   #1
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
Wink AS has ruined me.
I used to enjoy listening to the rain. Now, all I can do is stare out the window at my AS and imagine which seams and lights and vent stacks are leaking. Wonder which windows have a small rivulet of water running down between the skins, soaking the insulation and slowly oxidizing the steel hidden behind the belly pan.
It's unbearable. I won't be able to sleep until I Squirt vulkem along each seam, put new butyl tape under the fixtures, and coat the frame with Por 15. Even then, I may have to pressurize the whole thing and soap it all up just to make sure.
Is there some kind of anti-anxiety medicine available? What has happened to me? I used to be so carefree......
Just kidding, but I do think about it when it rains really hard.
robwok is offline   Reply With Quote
Old 03-06-2011, 05:23 PM   #2
pbearsailor's Avatar
Port Hadlock , Washington
Go out and sit in the Airstream when it's raining and listen to the cool sound the raindrops make on the aluminum and don't worry. How long did the trailer last without you?
Besides, if you're thinking about POR 15, you've thinking about taking it apart and doing the subfloor and all that stuff anyway. Only takes two or three years.
Forum Thread: First She Had to Take a Ride on a Boat
Blog: My 57 Caravanner
pbearsailor is offline   Reply With Quote
Old 03-06-2011, 05:36 PM   #3
Whirlaway's Avatar
2008 27' Classic FB
Anytown , Massachusetts
It just started to rain hard...and
I let the doggie out and walked over to the AS to pop my head in.
I had to check and make sure there were no leaks...
I guess we are all the same...wondering
Lin
Life Is Not A Dress Rehersal
It's okay to have too much fun
WBCCI #8701* TAC MA-1 * NEU UNIT
Gracie...A Liver & White GSP
Get busy livin', or get busy dyin'." - The Shawshank Redemption
Whirlaway is offline   Reply With Quote
Old 03-06-2011, 05:46 PM   #4
kevin242's Avatar
1977 25' Tradewind
Waskesiu Lake , Saskatchewan
Rain?
What's rain?
Every home needs a dog, and every dog needs a home.
1977 25' Tradewind (with two ... three... FOUR dogs)
2011 Ram 1500 Quad cab, 5.7 Hemi, tow pkg.
kevin242 is offline   Reply With Quote
Old 03-06-2011, 05:56 PM   #5
moparjohn's Avatar
1973 25' Tradewind
Ringoes , New Jersey
Your'e not alone!
moparjohn is offline   Reply With Quote
Old 03-06-2011, 06:24 PM   #6
OO , OO
Send a message via Skype™ to cruiser54
I (still) don't know this problem!?! But a similar one: In my ancient timber house I hear from the (new) central heating somewhere all from 10 to 15 seconds a "Blupp" - water drips from a pipe. I heard night after night on the walls - introduces to me what probably everything is in decay. I see no water stain, nothing becomes wet, but it drips definitely! It must be the heating, it makes only during the heating season "Blupp". I am glad about the summer!
Werner
cruiser54 is offline   Reply With Quote
Old 03-06-2011, 07:55 PM   #7
ddstech's Avatar
1958 22' Flying Cloud
Folsom , California
The cure is called "covered storage."
ddstech is offline   Reply With Quote
Old 03-06-2011, 08:08 PM   #8
Ottawa , ON
Rob,
Start with the easy ones first. Andy pointed out one that I think is the most common (the three tank vents on the roof) and relatively easy to do.
Get the screen pieces, make (or buy) a new gasket, get some Vulkem, and in one afternoon, you will have made a great difference.
Actually, your '64 probably only has two roof vents, right? You have no grey tank.
Old 03-06-2011, 08:42 PM   #9
tlsmit1's Avatar
1962 24' Tradewind
Saint Louis , MO
Originally Posted by Aage View Post
Rob,
ummm... does this mean we have to put a vent on the roof for every tank (new fresh water, new black water, and new grey water are planned...)
tlsmit1 is offline   Reply With Quote
Old 03-06-2011, 10:15 PM   #10
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
The vents are to allow sewer odors to escape. You do not need a roof vent for fresh water........depending upon your water supply source.
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 03-07-2011, 07:32 AM   #11
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
AS has ruined me.
Greetings tlsmit1!
I am guessing that you are converting your 1962 coach from a pressurized system to a demand system. With the demand system, there is typically an atmospheric vent for the tank combined with the fill opening. In the case of my '64 Overlander, the atmospheric vent is a very small opening in the "bunge plug" that covers the fill tube -- while on my Minuet, it is a screened tube beside the fill opening that is hidden behind the access door for the water fill. There is also an overflow tube that is typically directed through the floor and bellypan that allows for both expansion as well as relief when the tank is overfilled.
Good luck with your coach!
Kevin
Kevin D. Allen
AIR #827
Old 03-07-2011, 08:40 PM   #12
tlsmit1's Avatar
1962 24' Tradewind
Saint Louis , MO
Thanks very much. Do you know if it is ok to combine the grey and black tank stacks into a single roof vent (provided the combination is distal enough from the tanks to prevent mixing of contents other than gasses)?
rain, leaks
