Old 11-01-2008, 12:23 PM   #1
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
Apply Parbond in the rain?
I have a couple of small leaks around some rear window frames. Based on my prior experience with it Parbond would seal these nicely - if it was dry. BUT its raining cat and dogs here.
Will Parbond adhere to wet surfaces and cure properly?
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 11-01-2008, 01:07 PM   #2
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Not sure, but there is an aluminum base gutter seal that is colored that you can use wet...
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 11-01-2008, 02:38 PM   #3
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
No.
Originally Posted by guy99 View Post
... Will Parbond adhere to wet surfaces and cure properly?
First of all, the directions clearly state otherwise:
Originally Posted by H.B. Fuller Company
Surface should be clean and dry ...
Second of all, Parbond is full of volitales; Anything that one would want to squeeze in a bag & inhale means that the presence of water is a no-no. You know what I mean.
Not that I ever do/did that.
Wait for dry weather.
Tom
Old 11-01-2008, 04:18 PM   #4
guy99's Avatar
Images: 16
Tom
Well that seems pretty clear. Thanks.
My tube of Parbond is illegible, I'll leave it to imagination why.
Hint, who knows how long it takes for Parbond to wear off of your fingers?
Acryl-R How to apply? Dan S Leaks - Weatherstrips, Gaskets, Caulks & Sealants 17 05-07-2017 02:02 PM
Vulkem vs. ParBond 68Glbtrotter Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 10-04-2006 10:17 PM
Parbond (again) Peter&Denise Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 06-07-2005 06:07 AM
Apply anything after compounding? Bryanhu Cleaning, Stripping & Polishing 3 06-19-2004 12:13 PM
ParBond Shrinkage? Jabba Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 08-11-2003 01:12 PM
