Old 11-12-2018, 05:27 PM   #1
Reidsville , North Carolina
Antenna Patch
I noticed today that my rooftop antenna leaks. I'm going to remove it, as it is not connected. While researching patching the hole from the antenna I found this. I'm asking for input on weather this is worth trying as a patch.
https://www.easternmarine.com/vanfas...y-patch-v1212n
bombard16 is offline   Reply With Quote
Old 11-12-2018, 05:42 PM   #2
Kevin245's Avatar
I’m a bad example.
We patched ours with a 99 cent aluminum “For Sale” sign and a tube of urethane caulk from the local hardware store. That was 10 years ago.
William C. Swinney
Old 11-13-2018, 03:06 PM   #3
10 years and it doesn't leak? That sounds like a fix to me.
Old 11-13-2018, 03:46 PM   #4
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
The caulk / sealant is way more important than the material. Aluminum of any sort is highly unlikely to spring a leak ....
Pulling the Air TV Antenna Replace With A Satellite Antenna Chuhhuniban Electronics & Connectivity 11 04-03-2019 07:11 AM
Antenna Removal & Replacement with Cell/Wifi Antenna BoldAdventure Electronics & Connectivity 10 08-14-2017 07:24 AM
Antenna replacement vs. permanent patch stephenh2 Roof 9 05-05-2017 07:41 AM
To patch or not to patch... truckirwin Repairing/Replacing Floor &/or Frame 8 05-01-2014 05:18 AM
Body mods: To patch, or not to patch? Belegedhel Ribs, Skins & Rivets 0 01-05-2012 09:33 AM
